Question about Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum
Icemaker making ice
How long does it take for icemaker to make the ice?
  • 909 Answers
If icemaker is in good order, it will then depend on how cold the freezer compartment is and how available the dispenced water is. The ice maker draws the temp. from the freezer to allow activation.Size of ice depends on level of water in ice trays.
Posted on Jun 04, 2010
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 37 Answers
SOURCE: GD2SHA WHIRLPOOL ICEMAKER NO ICE
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: Icemaker is not making ice
check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
Posted on Apr 05, 2009
  • 1218 Answers
SOURCE: Icemaker not making ice.
First, it's important to know that the freezer must be at normal temperature. Any temperature above 15 degrees will cause the ice maker to lock out automatically.
Assuming it is normal, then follow these steps to get it up and running.
Check to make sure it is in the on position and check the water supply at the valve (covered in the steps below)
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 05, 2010
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    How to trouble shoot GE ice maker that is not producing ice
    Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Rick
    Mar 12, 2012 | Refrigerators
    Ice maker stopped making ice
    Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
    Aug 15, 2009 | Refrigerators
    Ice maker wont make ice
    Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
    Aug 12, 2009 | Roper Refrigerators
    Water but no ice. ice in tray
    If you have a "paddle" switch just below the icemaker make sure there is tension on it, i.e. the tension spring might be loose. Make sure the tension spring end is inserted into a tiny hole. Mine wasn't, I did it and ice maker works fine now.
    Jul 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
    There is water to icemaker but it does not make ice.
    Check if the icemaker inlet valve is opening and if the icemaker solenoid is working.
    If the icemaker has a filter also replace the filter.
    May 22, 2009 | Refrigerators
    Kenmore Coldspot w/Ice Maker Not Making Ice
    hi LOP7,
    In most cases you can easily solve this problem.
    step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
    Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
    If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
    If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
    Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
    Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
    Icemaker want stop making ice
    Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
    Samsung 26.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum Logo
    248 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
