Question about LG Computers & Internet
My flatron has touch "on" and it doesn't come on. Ive tried multiple times to get to come on since I got it (over a year ago) and basically I Just have to wait till it decides to come on.
  • LG Master
  • 6,993 Answers
firstly, check if the power button is stuck, that is, if its not contacting the monitor panel. Also check your monitor's power cable as it might be loosing contact. Do a general troubleshooting on the monitor and if it makes no difference, then it means your monitor is having a power problem.
A capacitor, diode, etc on the monitor's power panel/board maybe faulty. Until these bad components are replaced, the monitor might still behave the way its behaving.
If you know about monitor repairers, I would suggest that you open the monitor and read the power part/panel with a meter, detect the bad component and replace it. Take note that monitor stores a lot of current that can shock, so leave the monitor for a while before you open it.
If you don't know about monitor repairers, take the monitor to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Jun 04, 2010
Why does my radiator fan relay get real hot?
Sounds like your cooling fans are failing, causing an excessive load on your relays
Aug 10, 2014 | 1999 Chrysler Town & Country
Unresponsive touchscreen
You could try updating the phone firmware. If it is already up to date, try to re install the same firmware and see whether the problem gets fixed.
If not ; you may need to replace the touch screen/digitizer of your phone with a working one
Jun 17, 2017 | Cell Phones
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
Aug 10, 2012 | Computers & Internet
My LG Flatron L1715S works sporadically - it is blank when activated, but activates either by pushing the on-off button many times OR by rebooting several times. Is there a quick fix to this that does not...
No, sorry, it's not a simple fix. The usual reason an LCD monitor does this is because capacitors in the power supply fail. Then the inverter circuit which provides power for the backlight lamps doesn't work properly. In many cases, replacing the capacitors is all that's needed to fix the trouble, but it means opening the case, removing the bad parts, and obtaining and installing new ones. It's not a very difficult repair as far as repairs go, but it's going to need more than a screwdriver.
Many websites and videos are available that detail the repair procedure for different models, and capacitors are readily available from many sources. If you know someone who has some experience with electronic soldering, or you're willing to try it yourself, you might be able to rejuvenate this one. If not, you're probably best off buying a new monitor. Basic models are quite inexpensive now, and if you pay someone to fix yours it might cost nearly the same.
Jun 07, 2011 | LG Flatron L1715S 17" LCD Monitor
Hello, I got my LG Rumor Touch about 2 months ago, and I am having trouble with my touch calibration. There are many things wrong with the touch screen, and two examples are when i touch the numbers to...
It is hoped you bought this new because there is an issue with the digitizer(the glass plate that sits on top of your lcd screen and recognizes when you touch the screen). I've worked on tablets and phones for several years now and, unless you bought it new and with a warranty then your next step is to take it to a reputable phone repair service and have them replace the digitizer. If you hold the phone up flat and you can see ANY kind of separation between the LCD and the digitizer, then it will NOT function properly.
Sometimes you have to replace both the digitizer and the lcd as they are one piece.
Hope this helps.
Apr 25, 2017 | LG Rumor Touch
I first got my Flatron 1715S monitor about three years ago, for the first two years it was replaced due to multiple flies getting behind the screen surface. For the past two years i've just accepted the...
Get a technician to clean them out for you, for safety reasons. it is possible - by the way - to clean flies from the LCD except the fact that you must know how to handle such components as a LCD screen disassembled.
May 20, 2017 | LG Flatron L1715S 17" LCD Monitor
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Broken drive mechinism
Your warranty doesn not offer data recovery. Only a replacement. Many people are unaware of this so drive dompanies just forward those to a voicemail trap. Try investing in an enclosure that is more realiable, with a name that's reputable, you won't be left in the dark next time.....and considering it seldom if ever happens with seagate.
Keep me posted.
Oct 04, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Computers & Internet Logo
18 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
