Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Starting Pull Cord
I have a multi-tool Ryobi string trimmer/edger. The start cord has pulled out and will not retract. This has been happening for some time and with a bit of jiggling, the cord would retract. Now it is fully pulled out and will not go back at all. I took the machine to a small engine repair shop, but they told me it was not economically recoverable. They said on the bottom of the engine was a statement that said it was good for about 50 hours. The machine is much older than 50 hours and the engine works fine. Problem is I can't get the cord back in. What to do?
  • 420 Answers
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there and I'll need the model to know what to do next.
Posted on Jun 04, 2010
Testimonial: "I did not take it to the car wash, but will do what you say next time I have my power washer out. I used a screwdriver and got it into the little groves on the wheel which retracts the pulley. Little by little it went back in and you could hear a spring or something retracting. As soon as I got it all back in, I pulled it and it started. Thanks for the help."
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull cord on my ryobi s430 string trimmer doesn't engage to turn motor over.
Michael under the pull cord is a gadget that when you pull the cord two wings open and grip the starter. If you can get the starter off make sure these are coming out properly. It may just need a little oil on them.
Sep 13, 2013 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
The pull cord on my ZR29550 string trimmer is stuck in the fully retracted position. I can't pull it to start the machine. Also the electric starter can't turn it over.
well its not going to start with electric because the cord is out of it...
just take it apart becareful do not pull the recoil out or your in a mess....
but this should help you out if you need to know more just ask...
Aug 18, 2010 | Ryobi 15" Electric Factory Reconditioned...
Trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
May 22, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
How to pretension starter cord on ryobi whipper snipper
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
488 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
