Question about Dishwashers
The detergent door does not open during the wash cycle
  • 159 Answers
The detergent flap is likely faulty.this quite easy to replace.unplug first.remove the front panel by screws allong the side when the door is open.the doorskin or panel may be a bit stuck to the inner door skin due to foam insulation that melts & sticks them together a bit.after removed you can see the rear side of the soap container,there should be screws to undo it,just remember where the couple of wires go.Goodluck!
Posted on Jun 04, 2010
  • 909 Answers
2 types of methods to open detergent door. 1) Thermally. Rotors turn and spray hot water onto plastic structure then it would open thermally.Check and ensure the rotors are clean and free to turn. 2)Electrical solonoid is used on some. At a certain time in the cycle, a pulse will be sent to the solonoid on the detergent appatatus. this will then open the door.
During the wash cycle the detergent door will not open to dispense the detergent
Make sure your door does not have a build up from previous detergents.
Aug 24, 2010 | Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Detergent door does not open during session
Sounds like a bad dispenser solenoid, or it is not getting the prompt to open from the controller or timer and it also sounds like it is still under warranty, get them out to look at it while you can.
Jul 21, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
