Question about Toshiba 1360 Black and White Copier
Copier is streeking
This copier prints out the first page clear, but the pages after that have black streeks on them . went throught the manual and did everything it said to do but still streeks.. we just changed the tonner and tonner bag. any suggestions? thanks..
    President:
  • 3,085 Answers
Replace the DRUM
Posted on Jun 04, 2010
SOURCE:
Black streacks on paper during coping
Odds are that you will need a new OPC drum & drum cleaning blade for the black lines > you may also, need a new primary charge roller & it also, depends if the black lines or marks may be coming from the fixing unit..... There are a lot different cause's.... Good Luck
Sep 06, 2012 | Panasonic WORKiO DP-2330 Copier
When i print on my hpc7250 all-in one printer the first page is blank. also i'm getting a streek on copies and scans when i use the feeder. can you help with these problems.
The feeder could have something like typex or adhesive stuck to the lens section. If it is accessible, clean gently. If not - you may need the help of a technician to clean it. On the first page being blank - could be cartridges that need a bit of priming before they work. When last have they been in regular use. Maybe you should replace them.
Feb 18, 2010 | HP Office Equipment & Supplies
Visible "streek" down the length of my copy
usually this is caused by dirt or wite-out on the scanner glass. List the feeder and clen the scanner glass.
Nov 23, 2009 | Office Equipment & Supplies
Black color streeks. Cleaned 3 or 4 times to get
it seems youu already did all the troubleshooting.
Heres the thing you need to do:
-Try to reseat the printhead then calibrate printer., you can calibrate printer by pressing menu scroll down and look for calibrate printer.
-Please download your latest firmware at kodak.com/go/downloads
If the steps did not solve the problem it means that the nozzles of the printhead is defective you may call kodak for repair Toll Free 1 800 421 6699., GudlucK!
Nov 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I get streaks of toner on the page and when I remove the toner cartridge (C3909A)and open the door their is a lot of toner on the drum. Will replacing the cartridge correct the problem or is something else...
if your drum is completely black of toner then its the charge corona or if it is only just partly with streeks and spots then its the drum.
Tip---- always check to see if the drum has done life in the counters.
good luck
Oct 23, 2009 | HP LaserJet 8000dn Printer
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 30, 2009 | HP Office Equipment & Supplies
LIGHT BUT DISTINCTIVE DARK STREEK TOP TO BOTTOM ON ALL COPIES
you do not need to replace the copier
the cartridge has a charger wire that you can clean with a pencil erasure
Also remove glass and clean the underside of the glass and the mirror
finally
open the fuser area( exit area where you clear jams and remove the wiper / cleaner of the fusr rollers
ad reinsert
look for any lines on the rollers
when you install the toner cartridge lift the shutter that exoses the imaging drum to see if it looks ok
if it has lines on it you may have to replace it ther is a wiper (silicone that will get toner nder it and can cause the lnes
All you can do is reinsert ant try it if it persists relace the cartridge
Jan 02, 2009 | Canon PC-795 Copier
I just changed the cyan cartridge on my HP3700 LASERJET COLOUR PRINTER. I believe it was defective...as my print jobs are now coming out with three streeks on one side as though something is being dragged...
Please ignore this request, as I have found a local repair shop to take a look at it.
I will keep you on file, if I have any other trouble shooting needs.
Thanks for checking.
Sep 11, 2008 | HP Office Equipment & Supplies
Cannon d880
Sounds as though some how you fixing assemby has been damaged and would need to be replaced.
Apr 21, 2008 | Canon ImageClass D880 Copier
Toshiba 1360 Black and White Copier Logo
153 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
