Just received Refurbished Advent CBE 1401. It is being replaced because power switch is faulty - but I have questions about machine. 1. When initially switched on the switch turned red is this normal? I could not switch computer off with switch. 2.There was no signal being received by monitor which I had plugged into monitor socket. (There was an adapor included for one of the other sockets -but I didn't get chance to try it as after I had attempted to reboot computer it refused to switch on at all) I am using an LCD monitor - SyncMaster 710N. 3. What is the switch beside the power unit on the back for? 4.How much space needs to be left between side of computer with fan.
  • 5,660 Answers
1) No. The switch color should have been Green
2) No Signal on the monitor, indicates the monitor is not receiving a Video Signal from the computer.
A) Could be due to a faulty monitor cable.
Monitor cable is used on a working computer for a test,
Or,
working computer's monitor cable is used on the Advent for a test.
B) Could be due to the graphics 'engine' on the motherboard, or on the graphics card is bad.
[Graphics 'engine'.
GPU
Graphics Processing Unit.
http://en.wikipedia.org/wiki/GPU ]
If the computer is using Integrated Graphics, the GPU is on the motherboard.
(Integrated Graphics is also referred to as OnBoard Graphics. Meaning On the motherBoard)
You will know if it's Integrated Graphics, because the monitor cable will be plugged into the VGA connector, on the motherboard
http://en.wikipedia.org/wiki/VGA_connector
Since you indicate an adapter was included, to adapt to a different port (Connector), it could be a VGA to DVI adapter, or a DVI to VGA adapter.
Your monitor may just have a VGA connector on the monitor cable.
Hence you would use a female VGA to Male DVI adapter.
Your monitor may be an LCD flat screen monitor, and has a DVI connector on the monitor cable.
Hence you would use a female DVI to Male VGA adapter.
DVI
Digital Visual Interface
http://en.wikipedia.org/wiki/Digital_Visual_Interface
VGA monitors are Analog.
LCD monitors are Digital.
A computer puts out a digital signal.
If a VGA monitor is used, the computer has to alter the Digital signal to an Analog one.
This slows down the video signal.
If your monitor (In any case. Not just this one), is an LCD flat screen monitor, it is best to use a DVI monitor cable, and plug into a DVI port on the computer, if available.
If your monitor is a VGA (CRT. Cathode Ray Tube), monitor, and you have a DVI connection on your computer, using the adapter will do you no good.
The adapter just uses the contact pins for VGA, that are present in that DVI adapter, and hence the DVI connection on the computer.
You're still just getting an Analog VGA signal.
Example of a female VGA to male DVI adapter,
http://www.directron.com/dvi.html
If the Integrated Graphics are suspected to be bad, a graphics card is used in the appropriate expansion slot, for a test.
If the graphics work then, the graphics card is left in service.
After I test the monitor cable my next procedure is to suspect the Power On switch, or the Power Supply, and go to the graphics next.
The reasoning is that Power Supply failure, is the number one cause of computer failure.
The next is the Power On switch, then Electrolytic Capacitors used on the motherboard.
(Specifically, any Electrolytic Capacitors used in the motherboard Voltage Regulator Circuit)
If the Power On switch is bypassed, the diagnosis will reveal if the problem is the switch, or Power Supply.
Bypass the Power On switch, and the Power Supply comes on?
Problem is the Power On switch.
[One Power On switch I have found to fit a lot of computers. The Power On switch goes into the plastic Power On button,
http://www.directron.com/atxswitch.html ]
Bypass the Power On switch, and the Power Supply does Not come on?
The problem is the Power Supply.
The Power On switch is bypassed using a jumper wire, from the green Soft Power On wire, to ANY black Ground wire. The contact made is a brief momentary one.
The jumper wire is used at the back, of the 20, or 24-pin ATX main power cable connector.
To be continued in an additional Comment.
Posted on Jun 05, 2010
  • joecoolvette
    joecoolvette Jun 05, 2010
    This is an example of a 20-pin ATX main power cable, and it's respective connector,
    http://www.playtool.com/pages/psuconnect...
    An example of a 24-pin main power cable, and connector can be seen by scrolling down further.
    Apparently someone diagnosed your computer, and found the problem to be the Power on switch.
    If I may, You could replace the Power On switch yourself, and have a working computer again.
    As I stated above, the Power On switch is inserted into the plastic Power On button.
    The switch I linked may not fit that Advent Power On button.
    The switch I linked, could simply have the switch hanging out of where the Power On button was.
    (Wires from the switch, go through the hole where the Power On button was. Switch hangs outside the computer case)
    Granted, not a professional approach, and may not be considered aesthetically appealing.
    Would result in a working computer again, however.
    The voltage used at the Power On switch is 5 Volts. (DC)
    Two C cell batteries produce 3 Volts (DC)
    Just food for thought.
    3) The slide switch located on the back of the Power Supply, is used to set the Power Supply to use the Voltage in your country.
    You will see 110, and 220.
    The USA uses 120 volts.
    Most of Europe uses 220.
    Some countries use 100 Volts. (Japan for one example to my understanding)
    Your residence, or place of business, uses AC electricity.
    Alternating Current.
    A computer power supply converts the AC into DC.
    Direct Current.
    (A flashlight battery is one example of stored DC electricity)
    The computer Power Supply also provides the necessary Voltages required.
    A computer Power Supply produces three main Voltages.
    1) 3.3 Volts (DC)
    2) 5 Volts (DC)
    3) 12 Volts (DC)
    If you are located in a country that uses 220 Volts, and you have the Power Supply slide Voltage switch set to 110 Volts, and you plug the computer into power, once you press the Power On button you can kiss your Power Supply goodbye, and maybe all of the other hardware parts inside your computer.
    [Motherboard, Processor, Graphics Card if used, Harddrive, etc)
    4) The components inside a computer are cooled by air.
    I recommend at Least 3 inches of room all around the computer.
    Myself, the computer tower sits on top of my computer desk, to the right.
    There are no obstructions around it anywhere.
    I don't want it tucked down towards the floor in my computer desk, because it will draw all kinds of foreign material into the computer.
    Dust, dirt, animal hair, people hair, carpet deodorizer, food crumbs, (It is possible), and lint, just to name a few foreign to the computer, materials.
    I use a can of compressed air for computers regularly on a basis as needed.
    Lately it seems to be a weekly project.
    (It's summer)
    (Computer unplugged from power, computer case open, work on a table, observe anti-static precautions)
    Want to see a computer quit way before it's time, leave the inside of the computer dirty.
    (Desktop or laptop)
    I also want the computer to have free access to the needed air.
  • joecoolvette
    joecoolvette Jun 06, 2010
    Appreciate the rating jmelsdon, you are most kind!
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
1405
Description: Faulty data of the print head.
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Aug 26, 2014 | Canon PIXMA iP3500 Printer
Oil leak underneath machine
Possible this can be from the gear box which could have leaked due to a faulty gasket or loose fittings. it is best to clean the area and observe the point of leak to confirm http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
I can't switch on my HCL laptop's wifi
Hi
There are several models of Advent laptops and as you have not told us
which one it is i have included a few of which maybe one of them will be yours i hope
Advent 7086 ---- Button next to the power button
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
hopefully one of these options may help you to activate your wireless switch
good luck
please let us know if this helped you
so that we may be able to help others
many thanks
Aug 16, 2011 | Advent Netbook
Short Pin/Headphone jack issue with NAD CBE 720 Receiver
It's logical since the headphones jack is connected at the main amplifier. Does your new main amp has headphones out?
Feb 20, 2010 | NAD T752 Receiver
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Advent 7203 laptop wont power up
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Computers & Internet
Would the wiring for this cq-c3100u be the same for a cq-c1401u deck?
http://service.us.panasonic.com/OPERMANPDF/CQC3400U.PDF
Owners man 3100
http://service.us.panasonic.com/OPERMANPDF/CQC1301U.PDF
Owners manual 1401
They don't list the harness part # on the 3100, they do for the 1401.
Panasonic support # 1-800-211-7262 Be patient! it normally takes 15 minutes to get to a tech, however they are worth the wait and will answer your questions. Hope this helps
Jun 24, 2009 | Panasonic CQ-C1401U CD Player
Chainsaw 141 oiler not working
Somehow you have ended up posting this question in the Sewing machine section, so I suggest you re-post under chainsaws or you will never get a response......I don't know about chainsaws myself I am afraid, but if you have a sewing issue, let me know !
www.bargainbox.com.au
Mar 22, 2008 | Sewing Machines
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
