Question about Acer Aspire 5315 Notebook
My CD Rom is not functioning
My DVD Drive is not functioning, how can I get it fixed?
    Novelist:
  • 162 Answers
Hi. I think you could try updating the drivers for your DVD drive or by deleting the upper and lower filters on the registry so that we could verify if this a hardware or software issue. follow this instruction on deleting the upper and lower filters on the registry:
  1. Click the Start button and click in the Start Search boxMy CD Rom is not functioning - 2_bing.gif.
  2. Type regedit, and then press the <Enter> key.
    Note: The User Account Control window may appear. If so, click Continue. The Registry2_bing.gif Editor window appears.
  3. Click the arrow next to HKEY_LOCAL_MACHINE.
  4. Click the arrow next to SYSTEM.
  5. Click the arrow next to CurrentControlSet.
  6. Click the arrow next to Control.
  7. Click the arrow next to Class.
  8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  9. In the right-hand pane of the window, click UpperFilters.
  10. Click Edit on the menu bar.
  11. Click Delete. The Confirm Value Delete window appears.
  12. Click Yes.
  13. In the right-hand pane of the window, click LowerFilters.
  14. Click Edit on the menu bar.
  15. Click Delete. The Confirm Value Delete window appears.
  16. Click Yes.
  17. Click File, and then click Exit.
  18. Click the Start button.
  19. Click the arrow to the right of the lock icon.
  20. Select Restart.
If this doesnt fix the issue this might be a already a hardware issue and consider replacing your Optical Drive. Hope this helps
Posted on Jun 04, 2010
How can I fix a non-working CD DVD ROM Drive. The
it depends on the original fault. can be the laser or the bus board
Oct 05, 2013 | LG GH22NS50 22X DVDRW SATA Drive OEM...
DVD FUNCTION WON'T WORK, what should i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 11, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
I can't import anything or burn a disc
A cd rom or dvd rom are not functional as burners. You need cd burner or dvd burner.
your question is not clear as to what configuration you have, but confirming that your hardware is capable of burning cd's / dvd's is your first step.
May 27, 2010 | Apple iMac HD, CD-ROM / DVD-ROM Carrier...
When i choose somewhere:
Hi there, This issue may occur if you accidentaly replaced the Msvcrt.dll file with a third-party version that does not contain the _resetstkoflw (recovery from stack overflow) function. inorder to resolved this issue please follow step by step procedure below.
  1. Insert your Windows XP CD-ROM into the computer's CD-ROM drive or DVD-ROM drive, and then restart your computer from the CD-ROM.
    NOTE: Some computers may require that you modify the basic input/output system (BIOS) settings before you can start the computer from a CD-ROM. For information about how to modify BIOS, see your computer documentation.
  2. At the Welcome to Setup screen, press R to start the Recovery Console.
  3. Press the number key that corresponds to the installation that you want to repair, and then press ENTER.
  4. Type the Administrator password, and then press ENTER.
  5. With the Windows XP CD-ROM still in the CD-ROM drive or DVD-ROM drive, type the following commands, pressing ENTER after each command:
    • cd system32
    • ren msvcrt.dll msvcrt.old
    • CD-ROM_or_DVD-ROM_Drive_Letter:
    • cd \i386
    • expand msvcrt.dl_ BootDriveLetter:\windows\system32
    • exit
    NOTE: BootDriveLetter refers to the drive letter of the boot drive. In other words, it refers to the drive where the Windows folder is located, which is probably drive C. CD-ROM_or_DVD-ROM_Drive_Letter refers to the drive letter of the CD-ROM or the drive letter of the DVD-ROM drive. The CD-ROM drive or the DVD-ROM drive are frequently located in drive D.
Hope this resolved the issue. Thanks!
Apr 06, 2010 | Microsoft Windows XP Professional
I have bought a Super slim external USB portable 24x CD-ROM for my Dell notebook. I can't get DVD's to play on it. The laptop recognises the removable device but there is no option to play the disc. Can...
CD ROM drive will play only 700 mb CD disks(normal CDs)...and not play DVD disks...u need DVD ROM drive to play DVDs....there is a big difference among both in it's function.
a DVD drive "may" play both DVDs and CDs....
but
a CD drive will "only" play CDs
Feb 18, 2010 | Computers & Internet
My cd/dvd (sh-s182d )rom read cd only but it wont response
CD/DVD ROM drives like yours employs two lasers to work properly, one for CD read function and the other for DVD read function.
It seems that your laser for DVD reading is either dirty or damaged.
Try an optical drive cleaner, if that does not fix it, you are going to have to replace the drive. If you have warranty then replace it or have it fixed. However, if your warranty has expired then the best thing to do is to buy a new one. They are not expensive these days so the price difference between fixing it and buying new should not be huge.
A lens cleaner disk should be available from most computer shops.
I assume you have proper software for DVD video playback like PowerDVD, VLC media player etc.
Oct 08, 2009 | ASUS Computers & Internet
I cant play a disc or DVD
Please try to reboot your laptop then go to CMOS Settings and detect the CD/DVD Rom and try to see if it is detected by your system. If it is detect ted then exit CMOS Settings and then load the Operating system you have and ope the DVD/CD Rom you have. But if it does not detect the DVD/CD Rom then i advice you to find a computer technician to help you fix the problem cause hardware problem is the main reason why it does not detect the disk drive you have, its either the connection bus is not properly plug or the Disk drive is damage or not functioning well.
Thanks
Aug 04, 2009 | IBM ThinkPad T30 2366 Notebook
Dvd-cdrom plays music-cd.Not dvd-cd :No Valide Drive/Disc Found
Simply change the ROM to DVD RW drive since this is an old PC and now days nobody uses a dvd rom but a dvd writer. It will be worth it since it can do all the functions and is also more hardy........sodeep
Apr 29, 2009 | Compaq Presario 7599 (173952-004) PC...
Packard Bell Easy note R1000 - CD/DVD Rom
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Sep 09, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
