HELPP!! How to connect ''bush dvdav11k'',to TV without DVD Player
I just bought ''bush dvdav11k'', and im having trouble connecting, i want to know how do i connect the surround sound speakers/sub woofer, directly to my Tv, without connecting the dvd player???
What are the Y/R/W coloured wires, and where do they go, since the back of the subwoofer only has Black/Red/white??
HI,
I TOO HAVE BOUGHT THE AV11K. I TOTALLY HATE IT. ITS LIKE ITS BEEN CO-DESIGNED BY THE EUROPEAN SPACE AGENCY AND THE PLAYER AND WOOFER/AMP DONT FIT TOGETHER.
ID LIKE TO SAY THIS THING IS SO POORLY DESIGNED IT REALLY WOULD BE WORTH SENDING IT BACK FOR A REFUND.
ON THE BACK OF THE PLAYER, AND THE WOOFER YOU'LL FIND LETTERS. IE LF,LB,,,,RF, RB. (LEFT FRONT , LEFT BACK ECT). USING THE 'TULIP CABLES SUPPLIED YOU NEED TO CONNECT THE WOOFER AND THE PLAYER TOGETHER MAKING SURE THE LETTERS CORRESPOND.
DO THIS FOR ALL THE CONECTIONS ON BOTH THE PLAYER AND THE WOOFER. THERE SHOULD BE NON LEFT OVER.
THE LETTERS CORROSPOND THE THE POSSITION OF THE SPEAKER IN THE ROOM. SO ( I ADVISE YOU GET A REAL OF EXRTA SPEAKER CABLE FROM EBAY FOR A COUPLE OF POUNDS ) AND PLACE THE SPEAKERS IN ALL THE FOUR CORNERS OF THE ROOM THEN FILL IN THE NEEDED CABLE TO MAKE IT REACH THE WOOFER, WHICH MOST LIKELY YOU WILL HAVE BESIDE OR BEHIND THE TV AS ITS MOST CONVENIENT THERE ( WOOFERS ARE BASS MAKING SPEAKERS AND DONT REALLY CARE WHERE THEY ARE PLACED IN A ROOM.)
YOU SHOULD BE READY TO GO NOW.
THAT IS IS YOU CAN GET ANY SOUND TO COME OUT THE SURROUND SOUND SYSTEM ( LIKE I COULDNT).
THE SMALLER REMOTE IS FOR THE SOUND. THIS CAN BALANCE LEFT AND RIGHT AND VOLUME. AS WELL AS SELECT A AUX INPUT SUCH AS AN IPOD ECT. ( FOR THIS YOU WILL NEED A SIMPLE 3.5 > STEREO PHONO PLUGS. SIMILAR TO THE ONES USED BY THE AV11K.)
WHY IN HELLS NAME THIS SYSTEM IS ON THE MARKET I DONT KNOW. GOD PLEASE RE-ANIMATE MY LAST, AND TRUSTY PHILIPS DVD PLAYER..
HOPE THIS HELPS ALL UNFORTUNATE AV11K BUYS.
YOURS SINCERELY,
ALEX
Posted on Jun 05, 2010
I have a Bush 24 Inch Full HD 1080p Digital LED Backlit LCD TV which i bought 2days ago. I set it up according to instructions and it seemed fine, watched a couple of dvds on it (via a Phillips dvd...
This trouble is commonly cause by a weak signal, try to check all the jacks that is connected to your lcd and dvd there might be a loosed connection.
Jun 07, 2011 | Televison & Video
How to connect Bush dvd player to Sony television
You haven't specified what hookups you are using, so I am going to assume they are RCA.
Both devices should have one or more sets of these (picture below) yellow, white and red jacks. You will need to use supplied cables or buy some RCA cables and simply connect them to the back of the DVD player (matching the colors of course) and connect the other side to the video in on the back of the television. Once it is connected, turn on the DVD player and switch the sources on your TV.
May 04, 2011 | Bush DVD2038 DVD Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
BUSH PRO300/AR
hi.
the inputs are not for a tv.
they are for a 5.1 dvd player or similar device, the dvd player will have the same corresponding outputs, join them up and hey presto, sound.
hope this helps
Sep 17, 2007 | Audio Players & Recorders
Dora Tv & Dvd
How are you connecting the two? A/V input jacks? Are you selecting that input (line 1, line 2, etc...)?
Sep 12, 2007 | Emerson Dora The Explorer DVD Player
702 people viewed this question
 Grubhead
Grubhead
