Question about ViewSonic VP230mb 23.1" LCD Monitor
Power supply problems (failures).
We have about 200 of these beasts at the Hospital. After a year or so of continuous use, the power supplies are crapping out.
I need a schematic and possibly a parts list if possible. These things have recently become a main't responsibility for me.
TIA,
Tom
tnwoods@bellsouth.net
  • TomTurkey Apr 09, 2008
    Dan,
    The whole monitor is dead. They have been provided new p/s units by the Mfg. without charge, but that is now all changed. I guess that was about to get expensive. That's when they put them off on me.
    A schematic is all I need. Been doing this sort of stuff for about 25 years, but the work load doesn't support my reverse engineering and autocad drawings.
    Thanks, Tom tnwoods@bellsouth.net
  • 3 Answers
You are talking about the Veiwsonic VP230mp right!
The supply is 12 volts at 7.5 amps.
Got some here we wit bad smps.
One had a bad PFC chip and the other has an intermitting start up.
Solution is trash the inside ps and hook up an externat one. Any 12 volt-10 or 15 amp ham supply will do.
Inside you have to trace out the main dc connection and solder to these and supply it wit outside supply.
Easy fix.
If anyone knows the failure cause on the internal SMPS chime in.
Posted on Apr 14, 2008
Hi Guys,
We have detected one faulty chip (DIL8 box ref:13843 from ??)... The problem is that we didn't find any supplier for it.
There is another faulty chip that we found (DIL8 box ref:LM358D from Philips)... This one is easy to get on the market.
Do you have any supplier to propose for this component? Do you have spre component already?
Thanks by advance.
Julien
Posted on Sep 10, 2009
Pleasse send any solution abaut this problem
Regards
Gus
Posted on Oct 09, 2008
  • 4,234 Answers
Do these units not turn on at all or is the back light not functioning? I'll contact you off line for more about this.
Dan
Posted on Apr 09, 2008
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
How to solve error code E000000 - 0001
The temperature of the fixing assembly is abnormally high.
While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
Nov 21, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
What fuse to be used for power supply from vessel to EV-200 ?
Go by what the manual says. That spec is for the input current , not the output current.
Sep 19, 2017 | Boating
My desktop problem was do not re booting
hi check the power supply unit first, if those output voltages are present and no voltage drop, which supply the mother board as will as for the hard drive. if power supply failure it will not continue to reboot the system. removed the power supply then repair it, however you can replaced with new refurbished power supply unit. hope this will help thanks for using the fixya good day.
Oct 23, 2011 | Computers & Internet
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I am using AOpen 200-Watt Power Supply, suddenly, it has a problem: No power output. Maybe any diot is broken? How to dectect and replace it?
200 watt would mean it is a few years old so it could eb a few things. Power supplies can be prone to heat damage if never cleaned out. It's cooling fan gets plugged up just like your cpu fan. The ehat will kill off weak parts.
Generally what fails on these are the big power transistors (mosfets) and sometimes the power capacitors. Easy to replace if you can solder. There is also a fuse on the board that sometimes goes out.
If you can't solder then its not really worth trying to fix as a new power supply is so cheap. You can find a 350 or 400 watt for about $20 brand new.
Apr 21, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
My power supply had ashort circuit smell burnd,
This power supply is a standard power supply that will handle 200 plus watts.
It can be replaced with just about any ATX supply and really would be a waist of time trying to trouble shoot it.
Any 24 Pin ATX supply will work just fine in its place.
Nov 29, 2009 | AOpen (FSP200-60SAV) 200-Watt Power Supply
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
ViewSonic VP230mb 23.1" LCD Monitor Logo
451 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
