Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D40: Green line on pictures
There is a green vertical line that is forming on my pictures. Can you give me some help to prevent this
    Champion:
  • Nikon Expert
  • 225 Answers
Hi b_a_johnson1, Is this on all photos in the same location and using different lens? If so there are two possible explanations, one is the sensor needs cleaning, the other is the sensor is going out on you. First try cleaning your sensor, not difficult though you need the proper devices. Do not use alcohol and a Q-tip! If it is the sensor going out it must be replaced. First do a reset on the camera, page 36 of the manual. Open the left side rubber terminal cover, just below the USB port is a small button. If that does not work call Nikon at 800-645-6689,
Posted on Aug 25, 2010
Nikon D40 green light flashing even when off
Sorry to hear this. Dropping something on concrete creates a high G force. Can you make sure the battery is fully charged before you put it in. If you have a good battery and all it does is blink something must have been broken. I think a D40 is a rather old camera too. Sorry I do not think I can help you. In most times a LED green blinking means it is charging. When carrying a camera you should wrap the strap around your wrist. If you do it correctly if you drop your camera it will not hit the ground. It is best to keep it from dropping on the ground.
Feb 06, 2018 | Nikon D40 Digital Camera with G-II 18-55mm...
I just got a nikon d40 and i can't figure out how to set it up or get it where i can actually take a picture with it
there is a way to "reset" the camera to the factory defaults. this will get it working . turn on the camera, there are two "green dots" near buttons on the camera. one is near the on-off switch, the other is on the lower left back of the camera. after the camera is turned on, press and hold both of the green dot buttons together for a few seconds. release the buttons, most of the cameras controls will now be reset. turn the know on the top right of the camera to the little green icon, this is full auto setting. Most nikons will not take a picture if there is not a memory card in the camera! the see if it is not working because there is no card, turn on the camera and press the upper left button on the rear of the camera. it will tell you if it has a card or not. if it has a card installed you should be able to take a picture.
Jan 01, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
A green line is being display on the LCD display.
That is a faulty LCD panel, if it's under Warranty, then take it in for service, if not, I wouldn't bother as it is costly (but up to you)
Cheers.
Sep 30, 2009 | Cameras
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
Photos are white
Are you using the camera in manual mode(M)? turn the dial to AUTO(green icon)
Mar 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The flash on my camera
There is no top LCD on the D40. Put the camera in AUTO mode (green icon on the dial) and take a picture in the shade. if the flash does not go o, then you have a fault. Send back to authorized repair centre.
Dec 09, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Initialization Error
try pressing the 2 green buttons to reset the unit . if you get lucky and it turns on, immediately follow the steps to update your firmware on this website http://ampin.wordpress.com/2007/03/02/nikon-d40-firmware-upgrade/ , otherwise you will need to take the camera to an authorized repair center . :)
Aug 30, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Nikon D80 Digital Camera with 18-135mm Lens Logo
265 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
