Question about Peavey Classic 30112 Tweed
I put a new speaker in my amp but don't know what wire is positive the blue or the yellow
  • Peavey Master
  • 5,603 Answers
Usually the yellow will be positive... Hint, it won't make a difference UNLESS you drive two of these in parallel as it only affects the phase of the cone movement relative to the input.
Connect the yellow to positive and don't worry about it further.
Posted on Jun 04, 2010
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Peavey SP 118P speaker leads...blue and yellow? which one goes where on the speaker?
Blue should go to red. I assume they used an Asian standard. Rough way to remember- sky blue, return brown/ground is green yellow- same potential as brown. yellow somewhere in between.
However reversed leads are not going to be noticed on the speakers of a single amp/speaker. Or if a multi speaker setup in a cabinet as long as all are mated with the same polarity.
It just translates to the direction a speaker cone is moving in relation to the magnet when the polarity of the sine wave peak is positive.
In a stereophonic setup- many can hear the difference an out of phase speaker can make, in a monophonic setup- no one is going to hear the difference. And on a stage setup, unless the speakers are all attached to the same source, they are all moving independently.
Feb 17, 2012 | Peavey Music
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
Feb 03, 2012 | Peavey SP2 PA Passive Speaker
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
Jan 12, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
Need to find out which is the proper speaker wires for hook up yellow to tweeter or sub? And striped one is positive or negative?
You can probably trace which colors go to the smaller of the amps... Yellow is often used for tweeter but there really is no standard. Striped wire is probably the minus lead. If a pair is heavier, that would be the pair for the woofer... and red is often positive for woofer and black the minus. Searching the Mackie schematics doesn't really show colors. You could call their service dept.
Dec 14, 2010 | Mackie Th15a Power Speaker Pair 15 Two Way...
Wiring diagram
Blue should be positive
Aug 05, 2008 | Yamaha Music
Peavey Classic 30112 Tweed Logo
65 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
