Question about RCA Universal Remote Control
The directions say push the button for the component to be programmed, and it should stay lit it does not stay lit.
    Scholar:
  • 103 Answers
According to the directions I found, it is required that you keep holding "code search" when you press the component key. I'm not sure what your directions say, but perhaps you need to hold the "code search" key until after you program the remote? I may help if I had the model number for your remote. Good luck! Der Strom
Posted on Jun 04, 2010
What do i push to put in codes
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 17, 2012 | RCA Universal Remote Control
How to program emerson jumbo universal remote to jvc tv model dvd component
Click here to download the user manual to Jumbo remote controls. it will have all details.
The common proceedings are:
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 21, 2012 | Televison & Video
Program my remote
Direct Code Entry
Code Search
Jun 11, 2012 | Televison & Video
How do you program the remote URC60231-00R01 3RC32B-1167
Direct Code Entry
Code Search
Jun 10, 2012 | Televison & Video
Instructions and programs
Direct Code Entry
    CODE SEARCH METHOD
Apr 26, 2012 | Televison & Video
How do i program without remote control? or how to program the remote control?
Direct Code Entry
    Code Search Method
    For more details enter this blog
    electronicshelponline[dot]blogspot/
Apr 07, 2012 | Televison & Video
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Nov 16, 2007 | RCA 3-Device Universal Remote with...
Lost directions and code for setup
Here's how:
Turn on the electronic you will programming the code for.
Press and hold the CODE SEARCH button until the red indicator stays on, then release the COE SEARCH button.
Press and RELEASE the desired mode button (TV, VCR, etc.). The red indicator blinks quickly, then stays lit.
Enter the 3 digit code from the code tables.
With the device on, press CHANNEL UP on your remote. If the device responds, no further programming is required.
(I have the code chart, if you tell me what components you have, ie reply to this post, I will give you the proper codes.)
Nov 05, 2007 | Philips PM4S Remote Control
Televison & Video Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
