Question about Sharp Notevision PG-C45X Multimedia Projector
The screen is dark all the time, we have tried reforming that didn't work. It says the lamp is fine with plenty of time left. any ideas of why it is so dark? This has just started
  • 75 Answers
I am not sure what you mean by reforming but have you check your brightness and contrast adjustments.
Posted on Jun 05, 2010
How do you relace lamps on plasma tv
New to this, I to have noticed top line dark left to right. Never thought to change. Will have a go myself, wonder were lamps obtained from, try google search. Yeah
Sorry not to answer question, should think it is a screw driver job and patients including health and safety measures. If you do, make sure plenty of cloth material to rest screen
Jul 21, 2014 | Samsung Televison & Video
Dark Screen on Acer Aspire 5735z
That sounds like the bulb in the screen is blown. I have changed them at times but it is very tricky and I'm pretty sure you won't find a reputable place to do it for you.
Effectively in answer to your question the only rational solution is to change the LCD panel, it's not very difficult to do on the aspires, just a few screws and peel off the tape holding the screen connector in place, disconnect the inverter cables, (pink and white) and swop for the new panel. check ebay etc for a new LCD panel they're not that expensive. Try to get a new one instead of a second hand one. to find out what panel you need, you'll have to open the screen and look at the back, it'll have a paper sticker showing the model number.
Jun 12, 2013 | Computers & Internet
RCA 42" LED TV Has Picture Issues on Half of the TV
It sounds to be a back-light CCFL lamp fault. Check the lamps for uniform illumination all the way. See whether there is dakened ends to them.
Jun 07, 2013 | Televison & Video
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
Hi i have a bluish tinge on screen?
clean the entire optics of your projector.
Oct 09, 2009 | Hitachi Performa CP-RS55 Multimedia...
Lcd screen won't work on my satellite a205-4617
I think the LCD circuit might be faulty or the lamp is defective.
Can you look closely to see any pixels switching on and off in dark background?
If the lamp/ lamp circuit is faulty it would be little cheap to fix.
Also please try with the external monitor once as leecom72 said ...
Nov 16, 2008 | Toshiba Satellite A205-S4617 Notebook
Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Dec 11, 2007 | Televison & Video
Sharp Notevision PG-C45X Multimedia Projector Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
