Question about Paragon Hardware & Accessories
CAN YOU SHOW ME PARAGON TIMER 8045-21 THE WIRING DIAGRAM PLEASE
HI, I RECENTLY SAW A LISTING ON EBAY FOR THIS ITEM. THE PHOTO SHOWS THE WIRING DIAGRAM.
HERE'S THE LINK.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=110619214541&ssPageName=STRK:MESE:IT#ht_843wt_1139
Posted on Dec 02, 2010
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2013 | Paragon Hardware & Accessories
Need a wiring digram for a pargon5x455 defroist timer
5x455 is WW Grainger number for 240Volt time initiated - time terminated Paragon 8045-20 timer.
Open following links to identify timer and download wiring diagram:
http://www.grainger.com/Grainger/PARAGON-Time-InitiatedTime-Terminated-Defrost-5X454?Pid=search
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
Aug 21, 2011 | Paragon 8145-20 Defrost Timer
I need a wiring diagram for a three phase paragon timer model number 8145-20.
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Link below has wiring diagrams and wiring manuals for 240V 8145-20
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
I need wiring diagram for Paragon 8154-20. The plastic board has melted
I think you have the 8145-20 240V
This is a time-initiated defrost timer
Paragon 8145 page
http://www.uni-line.com/modules/catalog/SearchResults.aspx?mode=productsearch&prodID=8145
Wiring for 8145
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
Wiring diagram shows both 120V and 240V
L1 L2 is 240V
L N is 120V
Website that explains defrost cycle
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 11, 2010 | Paragon 8145-20 Defrost Timer
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
How do i wire a Paragon 4001-00 timer?
Link below has wiring diagrams for 4001-00 timers:
Manual with wiring diagram:
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Aug 13, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
I have installed 3 paragon timers and this is the first to give me trouble. When the defrost cycle started it did cut off but the timer was stuck on defrost. Many techs have done strange things to the...
You need someone to come in and trace the wiring if you cannot figure it out. You said you had the Paragon wiring diagram already, if not the link below can be used.
This defrost time can be used for both hot gas and electric heater defrosting so check to see which defrost type is being used.
Feb 05, 2010 | Paragon 8145-20 Defrost Timer
Hardware & Accessories Logo
509 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
