Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
WILL NOT PRINT CODE E000002-0000
  • 1,219 Answers
this means that there abnormal readings of temperature in fixing assy.
To get rid of the error you can do two things:
First:
Press * ( add. function key )
press 2
press 8
Press *
This will allow you to enter service mode.
Choose COPIER
Under FUNCTION tab, choose CLEAR and choose ERR
This will clear E002 error.
Turn off and on.
If it works, that means that because of i.e. blocked vent cover, or too much of a/c,... had influence on temperature readings in fix. assy.
If that doesnt help, you need to replace fixing film assy.
Hope that helped
Posted on Jul 08, 2010
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Posted on Mar 03, 2010
I have a konica minolta 280 an there is a code c4101 . how to clear this code
The print head is bad.The print head is what houses the LASER. Its a large assemble under the image units. Open close the front door and or the right door.to reset the code. if it come back replace the print head, but also check all connectors to current print head and control board the controls it.
Jan 08, 2016 | Konica Minolta Bizhub C280 Color Copier
Finger print register code for xpressmusic 5800? i install in my phone finger print he is asking register code i love this application thank yu
contact the applicatin finger print support center and ask for the code
usually the code is not free, you must buy for the code
Feb 19, 2011 | Nokia 5800 XpressMusic Smartphone
Data entry green light flashing. Users sending print jobs to the MP6000 are not finding their print job done. Print job history shows 0 jobs.
Make sure that a user code is not programmed in the copier itself. If it is programmed, the print driver on the computer must also contain the code.
this code can be entered in the properties menu under the "access" tab
Oct 14, 2009 | Ricoh Aficio MP1600SPF Copier
Panasonic DP-8045 printing with a Mac
the device needs to have postscript firmware installed as it comes standard with pcl firmware.
Apr 29, 2009 | Panasonic Workio DP-3010 Printer
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
Please help abt VB6 code for SATO CX400 printer
just make prn file or by crystal report
call me on 9974985001
Print source code of an Access Database
Hello cbw@netzero.com,
The source code request would be for a program code, appropriate if you actually wrote the code for the Excel program, but if you are copywriting a set of formulas or an excel execution sequence, then you want to print your formula view for copywriting.Excel has a Formula View that shows the formulas on your worksheet rather than the results of those formulas. You toggle between Formula View and Normal View by pressing CTRL ~ on your keyboard. Just toggle to formula view and print your worksheet to see all of your formulas.
Good luck with your copywrite!
Oct 06, 2008 | Microsoft Office Professional 2007 Full...
I have error code 07,010.43:41518 What does it mean?
That is caused by the print head not pivoting from home to print position.
Here are the probabilities.
1. The staineless steel pivot block, that the print drive shaft goes through has had some, most likely yellow ink seeping into it and had made it slow to move back and forth. That is the most likely issue.
2.The machine was unplugged or there was a power failure and the print head wiper blade has tacked to the print head.
3. The cables to the print head are hanging up not allowing free movement of the print head.
4. The Media path motor geat chain is out of timing. That is unlikely, but a possible cause.
The easiest way to prevent that code is to make sure the printer is level front to back and side to side.
Also, the print head is possibly bad.print head, but unlikely.
Jan 18, 2008 | Xerox Phaser 8400DP Thermal Printer
Computers & Internet Logo
259 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
