Question about Dometic RM2620 Refrigerator
No ignition Dometic RM2652 igniter does not work. I lit ref manually and it runs and cools.
  • Dometic Master
  • 6,674 Answers
Remove cover from igniter (follow thin wire from electrode,back to it) and test for 12 VDC at + terminal on igniter box. If you have 12 volts at + terminal, replace igniter box.
Posted on Jun 05, 2010
Dometic rm2652 re-ignitor
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
Sep 14, 2008 | Dometic RM2652 Refrigerator
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Rm2652 will not ignite on gas
blow out gas line with air probably cobwebs
May 20, 2014 | Dometic RM2652 Refrigerator
Fridge won't cool on AC, the pilot will light, but will not stay on. Dometic rm2352 will not cool at all
Sounds like you have several issues. One, the flame not staying on is probably due to the igniter not sensing the presence of the flame. Clean the end of the igniter and make sure that the gap between the tip of the igniter and the flame tube is approximately 1/8". If this does not correct the issue then the flame not staying on and the cooling may be the result of a bad board. If it does stay lit and still does not cool then you may have a bad thermistor. To the bottom left of the refrigerator you will see a black covered circuit board. Remove the cover and to the upper left of the board you will see two harness plugs. Unplug the lower harness that has two wires in it and let it run for 24 hours. If is does not cool down then you have a bad cooling unit. If it does cool down then you have a bad thermistor.
Jan 29, 2014 | Dometic RM2652 Refrigerator
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
May 26, 2009 | Dometic RM2652 Refrigerator
FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Aug 11, 2008 | Dometic RM2652 Refrigerator
Dometic RM2620 Refrigerator Logo
507 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
