Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Normal cycle never completes. Have to CANCEL to
Normal cycle never completes. Have to CANCEL to stop. Quick cycle works normally. KitchenAid KUDS01FL dishwasher.
Have had unit for 6 1/2 years - below average frequency of use.
  • chrizzoclark Jun 04, 2010
    hi.Does the water heat at all during the quick cycle? Iv'e found that in most washers these days that the element must get the water up to a certain temperature before it will progress any further through the cycle,if not heating then it will wash continually cold waiting to get hot.?
  • 30 Answers
Check the temperature is reached the setting temperature,
or replaced the control board
Posted on Jun 04, 2010
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
266 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
