Question about Kitchen Ranges
I have a problem with my older style monarch portable spa/jacuzzi .. when i turn it on it doesnt start up .. the lights on the control panel flash red/green/red green .. its a spa quip , 3 button electronic spa pool controller . i have tried resetting the button on the heater where the power lead goes in but that doesn't help . would appreciate any tips .. cheers , wazza .
  • bigwok74 Jun 04, 2010
    filters are out and water lines are good .. it just fires up for a sec then stops and the lights flash .. how would i release an air lock ? cheers
    cheers JavaMan .. u were correct in the manner that there was an obstuction in the line .. that was my angle once u mentioned it so i blew the hose thru some of the jets and back thru at the bottom where u open the valve to release the water when emptying .. left it for 5 mins , went back and it ran as per usual and is pumping and heating as normal .. hope it has solved the problem for good but not convinced at this stage ! so thanks for ur ideas , wouldn't have thought/tried that till u mentioned it :) very clever chap ... take care and cheers once again , Wazza .
  • 547 Answers
I don't have that exact controller, but when my spa controller did that the trouble was "low flow through the pump"
This can be caused by a pump that's failed (airlocked or just stuck and unable to pump water) or by dirty filters, or by pinched water lines.
Check for a power reset button on the pump, and clean filters if your unit has filters.
Posted on Jun 04, 2010
  • Rob C Jun 04, 2010
    When it fires up for a sec, does water flow at the normal rate?
    At this point I'm thinking one of two things:
    #1: water is flowing at the full rate, but the water flow sensor is failing or failed, so it *thinks* that water isn't flowing. In this case, the flow sensor or the wires to the flow sensor are the problem.
    #2: water is NOT flowing at full rate, in which case the problem is something blocking the flow or a failing pump. In this case the first thing is to check and clean filters (which you've already done) and then check for obstructions in the lines. If the lines are clear, then it's a matter of troubleshooting the pump.
    Sorry -- you specifically asked about an air lock and I forgot to address that.
    If it's an air lock, then the pump won't move any water at all. It sounds like it runs a few seconds when you first power up, so it does NOT sound like an airlocked pump.
My monarch spa wont turn on error 3 and heater light is flashing
check recirculation pump if ok check heater element and temp sensor
Mar 03, 2018 | Pool & Spa
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
