Question about HP PhotoSmart C4280 Laser Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
  • HP Master
  • 4,737 Answers
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Posted on Jun 04, 2010
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Everything prints in shades of pink. Do I just
You most likely need a new black HP 15 cartridge.
Dec 13, 2009 | HP DeskJet 940c InkJet Printer
Can't get word to print from c4280 but will print from the web
When you select 'Print' from MS Word, what printer is listed? Make sure it is the HP C4280 and make sure 'Print to File' is NOT checked.
Aug 03, 2009 | HP PhotoSmart C4280 Laser Printer
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
gary.schaut@gmail.com
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
Manual required C4280
Hi Go to www.hp.com enter model number into search box, follow links through to manuals, check its the one you require, if so download
Nov 03, 2008 | HP Photosmart C4280 Aio Printer
Only prints in pink
Needs a New logic board which are nbot available
Apr 28, 2008 | HP PhotoSmart C4280 Laser Printer
Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Apr 14, 2008 | HP PhotoSmart C4280 Laser Printer
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
HP OfficeJet R40 only prints in pink
I had 3 bad printing cartridges. I went to Staples bought a new 23 and everything is printing fine now.
Feb 29, 2008 | HP OfficeJet r40 InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
300 people viewed this question
Seeker5211
Seeker5211
