Question about Furuno GP7000/NT GPS Receiver
Where do i buy a nmea signal cable MJ-A6SPF0003-050
I HAVE THE NEW MAGIC JACK PLUS. WHEN I PLUG IT IN I GET A MESSAGE TO WAIT TO REGISTER. I HAVE WAITED OVER 1 HOUR. HOW MAY I REGISTER?
Waiting, 'time" will not resolve this issue. Its a common problem where the MJ isn't talking to their servers. i would check your internet connection to the device as a first step. Change ethernet cable, even if the one you're using has worked before. Weird things happen to cables, some unseen....its always easier to assume a cable is bad and replace it or if you know how, test it within your own network.
The other solution would be to check on what ports are open for the MJ through your router. Offhand I cannot remember what it requires, but it could be that the router is blocking the signal, so the MJ cannot find the servers it needs.
Other than that, there a ton of tech support written on the MJ and the MJ Plus. I have both and had problems with the first two MJ's and didn't register my MJ Plus because I gave up on a home line.
I know that's not a simple answer, but I hope it points you in the right direction.
Nov 29, 2013 | Computers & Internet
Colour codes of output data cable explorer 650
From the owners manual (page 78, link below) NMEA out (+) is the white wire and NMEA (-) or ground is the black wire.
-Steve
http://www.northstarnav.ca/upload/Northstar/Documents/EXPLORER_650.pdf
May 14, 2012 | Northstar POWER/DATA CABLE FOR EXPLORER...
Raymarine power cable no. R69074
Are you facing any problem with Raymarine power cable?
If you just want a replacement of Raymarine power cable no. R6907, then you can visit " http://www.ticketdismissit.com/store/products/RAYMARINE_POWER_NMEA_CABLE_R69074-373553-10.html". You can buy it online.
Hope this will help you. Good Luck.
Jul 18, 2011 | Raymarine Power And Nmea Cable
I have a Philips GPS Dantronik Navigater MK9 an now a Northstar VHF Marine Radio Explorer 710. I want to connect both over NMEA to get the position form the GPS to the radio. There are 7 different...
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
Jun 01, 2010 | GPS
Does this unit have a distress signal that a Nema 0183 data cable can attach to
See below:
GPS RECEIVER LEAD
Connects to a GPS receiver for position indication.
• An NMEA0183 ver. 2.0 or 3.01 (sentence formatters RMC, GGA,
GNS, GLL) compatible GPS receiver is required. Ask your dealer
about suitable GPS receivers.
Color code:
Yellow: NMEA IN (+)
Green: NMEA IN ( )
Feb 19, 2010 | Icom M302 VHF Radio
Installation raymarine st6002
The power cable of your 2106 acts as a data cable also. You should find additional unused wires on the cable. Locate the brown and blue wires. You will need to connect the brown wire to the "NMEA OUT +" terminal on the autopilot course computer and connect the blue wire to the "NMEA IN +" terminal on the course computer. Finally, connect the "NMEA OUT -" and the "NMEA IN -" to ground (preferably the same place that the Garmin is grounded (black wire). Be sure that the Garmin interface is set up for NMEA In / NMEA Out. That should get you going!
Feb 20, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
Furuno GP7000/NT GPS Receiver Logo
151 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
