Question about Whirlpool AWM8143 Front Load Washer
Whirlpool 6AWM8143 Front Load not starting spin cycle
does not advance to spin cycle tried several times
just remains idle washing drum moves left and right
turn knob manual to spin machine completes spin cycle
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewhirlpool 6AWM8143 Front Load not starting spin cy - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport model WFW8300SW Have error F-22 and F-28, how to solve it? Thks
Relates to an electrical/electronic problem
Try the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Hope this helps comment back if you need further help,
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontloader 6AWM8143
It's faulty contact the manufacturer or the seller
Feb 02, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
May 25, 2007 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
384 people viewed this question
Dan Webster
Dan Webster
Sal De
