Question about Refrigerators
LG fridge freezer GR572TVF the freezer works fine but fridge had water drops at the top, now is not working at all - temp. is about 14c have changed defrost switch but fridge still not working any ideas ?
  • Anonymous Oct 18, 2008
    Fridge not working, since July twice I have had to switch off the appliance for 24hours, when I switch it back on it works for a while but I can't keep doing this. Is it worth getting an engineer out to it, I was told the parts may be obsolete. So i could end up paying for a service call and have nothing at the end of it.
  • Anonymous Nov 02, 2008
    Yes same thing has just happened to my LG 572TVF
    Do I bin it or can I inexpensively repair it?
catriver
  • 878 Answers
SOURCE: Fridge & Freezer not getting cold enough
Welshons, Take a look at the picture Im posting. Did your evaporator look like it? If so your system may be restricted. This is a pretty common problem in Frigidaire top mounts. The good news is that it would be covered under warranty if it is not over 5 years old. As long as your condensor fan is running and the condensor is clean, evaporator not frosted up and evap fan running. I would think that you have a weak compressor or a restriction. Catriver...post back.
Posted on Oct 20, 2006
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
dutchman05
  • 487 Answers
SOURCE: Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
Posted on Apr 24, 2008
aborcass
  • 2651 Answers
SOURCE: does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Posted on Nov 21, 2008
  • 16 Answers
SOURCE: have a hotpoint rsf60 fridge/freezer,noticed
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Posted on Nov 29, 2008
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Fridge freezer not freezing
Click means overload tripping due to compressor drawing extra current due to overheating or wear and tear. Check running current mentioned on the specs sticker and if the same is ok. then relay must be checked.
Apr 05, 2012 | Freezers
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
I have a fridge-freezer. the fridge is working fine but the freezer isn't very cold, its about the same temp as the fridge. I have changed the temp dial but this makes no difference.
I Have a fridge-freezer, the freezer is now filled with ice/frost on sides and top, as if it were not frost free. I addition, the fridge is not very cold
Jul 29, 2008 | Refrigerators
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
