Question about Hayward H-series Electronic Gas Pool Heater H400
No ignition for hawyood pool heater h400 - Hayward H-series Electronic Gas Pool Heater H400
  • 33 Answers
Http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Replace igniter on h400
Open the main door, locate the 2 white fabric coated wires, they go down towards the base of the heater. This is your igniter, usually a 5/16 nut driver will be the tool you need to remove it.
Jul 04, 2014 | Hayward H-series Electronic Gas Pool...
Heater does not ignite. Not sure if it is not getting gas or if it is not igniting.
see if gas valve has voltage if so see if gas pressure is ok if ok see if ignitor has voltage or ohm it out should be about 78 ohms disconnected
May 08, 2013 | Hayward H-series Electronic Gas Pool...
Haywood h400 pool heater, flames coming out of flue
check gas if ok clean burners make sure it is a propane unit if a N in model number it is natural gas orfices incorrect and will overheat very dangerous
Sep 09, 2012 | Hayward H Series Pool & Spa Heater 400k...
The CE code is showing on screen
Communication error
If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
H-series Electronic Gas Pool Heater H400: I have an H400 with digital temp control panel, th...
It is likely the keypad that has gone bad. Not difficult to replace. But you want to be sure thats what it is, as it is an electronic part, that is usually not returnable. The part number would depend on the model of the heater. Likely it is a h400idxl2 heater.
May 16, 2010 | Hayward H-series Electronic Gas Pool...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
I have a h400 gas heater. keeps shutting off reading 1F code
If the heater is cycling on and off continuously the problem may be a dirty filter. Try backwashing and rinsing the filter before anything else.
Jun 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hauward H400 heater won't turn on
check pressure switch operation most heaters will not operate without sufficient water flow/pressure. You can use a multimeter to troubleshoot the wiring using the schematic. If its induced draft milivolt ignition verify there is suffiecient gas flow to the unit
May 25, 2009 | Hayward H - Series 400 Heater Top for In -...
Hayward H-series Electronic Gas Pool Heater H400 Logo
385 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
