Question about Saeco Royal Professional Espresso Machine
Grinder blocked Pressing button to make coffe the grinder starts to work for one two seconds and then the machine blocks. On the display you see grinder blocked
  • 1,089 Answers
Hi
It is either the grinder that is bad or your CPU that needs to be replaced. I have grinders but not a CPU.
Posted on Jun 05, 2010
  • Saeco Master
  • 1,711 Answers
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
What is problem of coffee grinder not working
if the machine is ready to go and the grinder not start check to see if is not block the grinder blade and if not block change the grinder with the same voltage one 120V or 220V
Feb 18, 2015 | Saeco Primea Cappuccino Touch Plus Coffee...
DCC-790 Cuisinart coffe maker won't grind
what showing on display ,when push to make coffee? If showing grinder block-then you have to replace the grinder to fix it. Try to grind coffee ,but without beans-if grinder start but rotate slowly -you have to replace grinder and change the brushes of the motor.
Oct 04, 2013 | Saeco Royal Professional Espresso Machine
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
The nachine make all the steps, but only can get
One most posible reason is that the grinding coffee passage is blocked so the coffee is not moving up the the group piston and the machine brues without any coffee in piston and you receive only water.
We sugest to move all coffee beans from grinder by hand and the remaing with the help of vacum cleaner. Try to s.ck also everything that is inside the grinding like grided coffee which probably stuck bettween baldes.
Now udjust teh grinder to 2-3 steps more gross coffee and try the machine again. If it works then you should have coffee but not with good cream at top. So try a coplue of coffe more and if everything is ok then ajust back the position of the grinnder but one step at the time so one step back one coffee.
Goo luck
Mar 25, 2010 | Espressione Caf? Dolce Aroma
New grind and display shows "grinder blocked"
This normally indicates due to the grinder being set too fine or oily beans being used.
Try setting the grind on 7 .
If it still fails the grinder will need to be unblocked and serviced.
Dec 07, 2009 | Gaggia Titanium Espresso Machine
Melitta mill and brew 10 cup grinder/maker
  1. Press and hold the TIME button for 2 seconds. The green TIME light will come on and display will read 12:00. The unit is now in the timer programming mode.
  2. Press "HR" and "MIN" button to program start time. Small dot in upper left corrner signifies clock is programmed for A.M. No dot in upper left corner means clock is programmed for PM.
  3. The Timer Display and LED light will flash 5 times to indicate that timer is now set. Press and release the TIME button. The green TIME light will come on.
Sep 06, 2008 | Coffee Makers & Espresso Machines
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Royal Professional Espresso Machine Logo
489 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
