Question about Duracraft DB101 Floor / Box Fan
Motor is getting power but is not working. Where
Motor (DM-518C) is getting power but is not working. Where can I get a replacement motor?
How can I change or test DM-TL?
code p 1402 refers to fuel tank leakage diagnostic module--motor malfunction===causes --fuel tank leakage motor diagnostic module motor
code p 1403 refers to the fuel tank diagnostic module ---valve malfunction
go to a service dealer and have the unit tested
it is possible that by replacing or cleaning the valve section , the problem will be fixed
Mar 31, 2016 | 2002 Hyundai Accent
1978 evinrude will tilt up but not down
Sounds like something is wrong with your tilt and trim motor. You can find some replacements below.
http://www.iboats.com/Evinrude-Power-Tilt-and-Trim-Motors/dm/view_id.269667
Apr 16, 2013 | Boating
How do i change the drivers side window motor an an 05 kia sedona
You have to remove the inner door panel to
access the window regulator
You remove the regulator & then the motor from it
You Tube Video will provide a visual of several
similar window motor replacement jobs
Go there-- enter your car,question ,details,etc--- then move
around the site to watch various things
Dec 09, 2012 | 2005 Kia Sedona
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
The zoom stopped working. does anyone know what to do?
This is the power zoom control?
Could be a burnt out servo motor that does the work.
I think there's no way out but a repair shop.
Sep 26, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
Green light flashing on timer. tv wont power up..just bought this house. wtv was left behind. i was told it works but i cant turn it on
Thats a common problem if the sets left unplugged or without power the DM caps drain and then wont charge when the power is restored. Its a easy fix usually just replace the DM caps. You can get the Mitsunbishi repair kit called the WS55859 DM repair kit from www.tvrepairworld.com which has the upgraded replacement caps and the CD with repair instructions.
Jun 14, 2011 | Mitsubishi WS-55859 55" Rear Projection...
The winch on my 518c cable skidder wont work right !!
I would check the hydro fluid, if you run low this may happen. also the may be a flow adjustment on the winch itself maybe an Allen fitting. Good luck
Apr 13, 2010 | Heavy Duty Associated Equipment 6002B...
2000 Hyundai Accent
00-30-001 2000 ACCENT DMTL DIAGNOSIS: DTC CODES P1401, P1402 AND P1403
p1402 - dm-tl air pump motor is shorted or disconnected.
2000 model year accent is equipped with a new enhanced evaporative emission system. this new system is capable of measuring leaks as small as 0.020" diameter. the new system pressurizesthe evaporative emission system with a diagnostic module for tank leakage (dm-tl), while the previous model's system appliedengine vacuum through the purge valve to detect system leaks.
service information
vehicles that have the check engine light illuminated and have dtc p1401, p1402 and p1403 stored in the ecm should have their electrical systems diagnosed related to the appropriate dtc. these codes are not related in any way to an evaporative emission system leak. the conditions that set the diagnostic codes areas follows:
p1401 - dm-tl air pump motor current draw is higher or lower than expected (normal = 17-36 ma).
p1403 - dm-tl changeover valve is shorted or disconnected
Jun 04, 2008 | 2000 Hyundai Accent
Computer codes
service information
perform the suggested repair
1. inspect for water in the dmtl by removing the 90° air inlet elbow and looking into the air chamber. if water or corrosion is present, replace the dm-tl p/n 31440-25500; air filterp/n 31453-25500; and pipe assembly p/n 31454-25500if corrosion is in the pipe. see detailed instructions on page3 for air filter replacement.
2. inspect for underbody coating sprayed into connector m52 at dm-tl. if underbody coating is present on the male or female connector, spray with electrical contact cleaner to remove the undercoating.
air filter (dm-tl) replacement instructions
  1. disconnect the 90° elbow from the top of the dmtl and insert a clean rag into either the elbow or thedmtl inlet connector.
  2. disconnect the dmtl electrical connector.
    1. disconnect the 2 hoses at the front of the canister (caution: silicone hoses tear/puncture easily).
    2. remove canister assembly and dm-tl as a unit (3 mounting nuts).
    3. disconnect the 2 hoses from the metal transfer pipes.
    4. remove the canister, air filter, and metal tube assembly from the canister protector by removing the 3 mounting nuts.
    5. disconnect the hose at the air filter.
    6. remove the air filter mounting nut and remove the air filter.
    7. install a new air filter.
    8. reassemble in reverse order.
Duracraft DB101 Floor / Box Fan Logo
137 people viewed this question
Top Duracraft Dryers Experts
richie46
Gil Shultz
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
