Question about Bionaire Heating & Cooling
My Braemar ducted gas heater keeps shutting off
My Braemar gas heater keeps shutting off, and won't stay on, will start up for about 5 mins and then shuts off, then if we turn off/ on again it works for 5 mins. no other gas problems, stove and water heater working fine.
We don't have the manual for this system either, as it was missing when we bought the house.
4 Suggested Answers
  • 5 Answers
SOURCE: braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Posted on Apr 28, 2011
  • 587 Answers
SOURCE: we have a braemar chronotherm IV plus It turns the
What type of heat, electric, gas or heat pump, did anyone replace the thermostat recently? Did he replace the capacitor when he replaced the motor?
It sounds like either an airflow problem or a fan or limit switch, possibly the thermostat.
Posted on Aug 18, 2009
wentlanv
  • 710 Answers
SOURCE: just installed a new visionpro
Hi niklok,
You have the thermostat hooked up incorrectly. Honeywell's directions are sometimes confusing. You should have power first to the thermostat and from the thermostat to the heater. You cannot have power running both to the thermostat AND the heater. That effectively assures a continuous ON situation. The black wire from the panel should be connected only to one lead from the thermostat.
If you need further instructions, please reply back with the number and color of wires coming from the panelboard and the number of heaters and the number and color of wires coming from your thermostat.
Thanks,
Handie Andie
Posted on May 27, 2011
My mr heater wont stay light unless its above 3. It only stays on about 5 min then pilot goes out. It is gas heater. What's wrong with my heater?
Theres a thermostat inside, if its too cold and not warming up the thermostat enough it will shut off because it thinks there is a problem.
Feb 07, 2013 | Heating & Cooling
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Furnace is 7 years old. Will not stay running for more than 5 min. Will start up again after shutting off and then run for another 5 min. Suggestions?
Check the air filter. Jump out thermostat to see if it stays running longer, if so replace thermostat. Make sure all return air ducts are clear of debris. If furnace has a Fan/Limit switch, make sure tabs are set at 100, 140 and 200. Sounds like something may be heating up and shutting unit off till it cools back down.
Jan 03, 2011 | Ruud Heating & Cooling
Braemar ducted heating wont switch on
Jul 12, 2009 | Heating & Cooling
My ducted heater is not working. It fires up initially but when it comes time to run the fan it just goes into wait and stays like that. It is a braemar te430. Any ideas?
Sounds like the limit or fa switch. To be sure which one, e- mail the manufacture for wiring diagram or specs. Thank-you-very-much!
Aug 26, 2008 | Heating & Cooling
Heating & Cooling Logo
589 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
