Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Ewf1074 flashing E10 and start /pause button
Ewf1074 elecrtolux washing machine flashing E10 and start /pause button flashing red colour. What is going on ?
SOURCE: E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Posted on Nov 30, 2008
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Posted on May 10, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Posted on May 09, 2010
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
Hi, We have an electrolux EWF1074 which is reporting error EHO There is no mention of this in the manual or on Google after a brief browse. Please advise. BK
First of all is the machine doing anything it should not be.That alarm code does not exist on our system,the closest is EH1 and this relates to Power supply problems or a faulty PCB.To cancel press and hold the start/pause button and the nearest option button for about 5 seconds,now turn the programme knob to position 10 then hold in the start/pause button and option buttons again till alarm disappears and E00 is showing.Then turn dial to 0 then back to position 1 then back to 0 to cancel operation.
Hope this helps.
Jun 01, 2010 | Electrolux EW1000i Front Load Washer
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
E40 = Door swich.
E50 = motor.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
399 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
