Question about Freezers
TEMP ON FREEZER IS NOT COLD ENOUGH WHEN SET TO -23 KEEPS RETURNING TO -9. there are three buttons on the top of the fridge, one with a speaker sign, one saying SUPER and the third with the degree sign. Have tried on and off but no joy. The led display shows -23 or so but after 5 seconds it returns to -9
  • 909 Answers
Sounds like you need to do a 12 hour defrost. If the evaporator is caked with ice, the thermistor(temp.probe.) will also be covered. the true temp wont be read in this state. Defrost and then retry. Take note of temp for a period of time. See if it ever goes to -20 as selected. If so then at a later date it goes off again, there is then a defrost issue. Suspect the door was left open accidentally.
Posted on Jun 04, 2010
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
My cpca 291 fxk problem is freezer frosting up and struggles to freeze things and fridge is not cold enough
sounds like your fan motor has seized or burnt out a winding,, this will need replacing. check by holding lid open to raise temp but at the same time hold down the button that the lid presses on when its shut, after about 10min the fan should run.
Nov 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
May 25, 2008 | Freezers
Freezers Logo
51 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
