Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Convergence IC's my tv is a apex model gb5108, i have changed the convergence ic and vertical ic and still have problems with lines going across.do you have any other suggestions on this problem.
    Problem Solver:
  • 7 Answers
Lines going across is a little vague but there is always the problem with the electrolytics (caps) around the vertical, be sure and get the one on the power supply too. Just change all you can find(usually 4-5). Thre are 2 convergence ic's if you didn't change them both, resolder the other one.
Then check the value on R519 for me.
Posted on Apr 15, 2008
Apex gb4308 43 inch projection tv
This is not my main field of expertise, in any case here is the link for a solution to same problem and same model. According to expert the problem is related to vertical chip fault.
http://www.fixya.com/support/t142256-apex_gb4308_multi_colored_horizontal_bow
hope it may help you
cheers
Feb 18, 2008 | Apex Digital GB4308 43" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
Apex 51' gb5108
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Apex Digital GB5108 51" Rear Projection...
Blue wave across screen
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Three colored lines across the middle...
Sounds like the vertical control IC has gone out. Replace IC N301 (TDA8351) and check or replace R370 (1ohm), R371(33ohm), and R380(1ohm). This shouldn't affect the sound but once you get video you might figure out what is wrong with the sound (control setting). The TDA8351 crosses to NTE7156 and shouldn't run you more than $10.
May 28, 2007 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
119 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
