Question about Dometic Rooftop RV Air Conditioner
Both A/C units on my Motorhome will not work with the generator
I have a 1997 Holiday Rambler motor home with 2 a/c units. Both should work with the generator. Only one works at a time. What do I need to do to fix this problem? The thermostat appears to be calling for both to work. When I turn the A/C off I hear a click in the one that is not working.
  • 2,272 Answers
There is a fuse and a relay on the controller board of the unit that has to be checked.If the noise you mentioned is a CLICKING noise then its most probably the short in the relay.But if the noise is somewhat chirping then its a blown fuse problem that is making other wires and connections in the circuit short.This both relay and fuse needs to be checked to confirm the fault.
But if fuse and relay both checks out OK then its time to check the controller board the fault lies in controller board.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 04, 2010
What are the interchange parts for a 1978 FORD HOLIDAY RAMBLER E series?
We do not have that kind of reference material here.
Aug 22, 2017 | Ford Cars & Trucks
Where can I find a wiring diagram for a 37ft Holiday Rambler Imperial motorhome?
contact manufacturer they will send you a PDF file
Apr 28, 2016 | RVs
Gas 1999 Holiday Rambler Endeavor. How do I remove the dog house?
1999 Holiday Rambler Endeavor 36 WGS Class A Motor ...
? 11:40
https://www.youtube.com/watch?v=7nsTuFfPZLE
Jan 17, 2014 - Uploaded by Parkwayrvcenter
Can you find Holiday Rambler Quality with a Slide Out and Low Miles for ... Normally that is impossible but Parkway RV Center has done it again ... ... Remove all; Disconnect ... 1999 Holiday Rambler Endeavor 36 WGS Class A Motor Home with .... 1997Holiday Rambler Vacationer class A gas motorhome ...Missing: house
Jan 07, 2016 | RVs
Where is the fel pump fuse located
1997 Holiday Rambler Endeavor LE ... The early F53 has a "fuse box" located under/in the dash somewhere near the steering column. ... fuel pump, ignition, headlamps
May 31, 2014 | RVs
Replacing the riveted clearance lights on a 1991 holiday rambler motorhome?
Grind the top of the rivets off, then with a small punch and hammer tap the rivet into the hole.
Apr 01, 2014 | Sharp R-1870 Convection/Microwave Oven
Trying to find location of my OBD connector on a 1997 Holiday Rambler 37' motorhome. it has the Ford 460 engine.
if i did not forgot, for 1997 Holiday Rambler, the OBD connector is below the steering wheel.
or you can ask the 24 hrs live OBD technical support, they will like to help you, good luck
Aug 03, 2013 | 1988 Dodge D-Series Pickups
Need operators manual for 1978 Holiday Rambler motorhome. Where do I get one.
We do not have any access to Any motor home manuals.
Jun 05, 2012 | Cars & Trucks
Dometic Rooftop RV Air Conditioner Logo
41 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
