Question about Ingersoll Rand Horizontal Electric Air Compressor 25 Hp, 120 - Gallon, 460 Volt, 3 Phase, ModelNo. 81295107
FAULT MESSAGE Model SSR-EP40SE SERIAL # G1238U93040 FAULT MESSAGE "START FAULT 1SL HOW TO CLEAR IT AND RESTART COMPRESSOR
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
Posted on Feb 22, 2009
braintrust
  • 62 Answers
SOURCE: I have a compressor # SSR-EP75 I would lioke to
ingersoll has a web site to down load manuals and parts list, i coulnot get in you probably have to be a dealer to access, but here is the web site www.irtechpubs.com do a search and find your nearest dealer then have him go to the website and down load the manual for you and have him e-mail it to you, also check your serial number i could not get anything to match that number in my search hope this helps
Posted on Oct 27, 2009
  • 12 Answers
SOURCE: we have a rotary screw IR compressor 50hp with
when does it shut down and what is the temp and pressure when it goes down.
Posted on Apr 29, 2010
The dashborad says suspension fault
Problems with the air suspension seem to be less frequent with the Sport than in previous Range Rover models, but they still do occur. One owner reports "Whenever my RRS is lowered to "access" level a suspension system fault message apprears.". Another reports " Had the RRS back less than 2 hours and another "suspension fault." Also kept receiving messages that the vehicle is raising slowly and vehicle will raise when system cools. Couldn't even drive because it wouldn't raise out of access mode. Anyway, back to the dealer. Picked the RRS up again today-dealer said the EAS compressor was faulty and replaced it. So far everything is ok." Overall, most of the problems seem to be related to bad suspension height sensors or bad compressors. Angus Wade of the Czech Republic had his suspension light come on when in Germany; it started yellow and then red, then disappeared when he stopped and restarted the engine -- and has not happened since. His dealer said they have seen this a bit.
Weak Compressor: An official Technical Service Bulletin (TSB) LS-204-004 addresses "ELECTRONIC AIR SUSPENSION (EAS) WARNING MESSAGE AND LAMP ILLUMINATION". This deals with the warning message "Suspension Fault - Normal Height Only" message appearing with the Air Suspension Warning Lamp on. Computer diagnosis shows pressure increasing too slowly or unable to pressurize, with no air leaks. The usual problem is the compressor exhaust valve sticking, causing an internal air leak when the compressor is active. The bulletin recommends renewing the air compressor (RQG500090 is the latest specification air compressor with a stronger exhaust valve return spring)and installing and updating the air suspension control module software using WDS disc 13 or later.
Suspension Fault Message (random): One owner reported getting random suspension fault messages on his brand new RR Sport purchased in June 2006, well after the fix was in for the weak compressor. His suspension Fault message and Suspension Warning Light (Amber) came on after 5 days of ownership. He stopped and restarted the car, which caused the light and message to disappear, but they came on again after 5 minutes. Later the same day, the warnings disappeared again.
I have heard that on 2006 models, EAS fault messages can be caused by an internal leak in the Air Suspension compressor exhaust valve. The fix is said to be replacing the compressor updating the software.
Hope helps.
Sep 09, 2011 | Land Rover LR3 Cars & Trucks
The dashboard says suspension fault
Hope helps.
Sep 09, 2011 | 2006 Land Rover LR3
Compressor will not auto start and when manually started it will not load it just keeps cycling the solinoid. its a ssr up6 30 60hz
First of I really need some more info. Model and serial # on tag on compressor.Does this up6 have a controller on it. First of all the unit will not load unless it has enough air pressure to open the inlet valve. Is the unit in modulation. If so you need to switch it to on/off line then start. if in modulation and the system/tank is empty there is no air pressure to operate the modulation feature. I would start by switching it to on/ off line first. After started and air in system you can switch to modulation and the unit will operate fine as long as there is air in the tank/ system.
Jun 22, 2011 | Ingersoll Rand Air Tools & Compressors
I have an Ingersol Rand SSR-EP40SE Rotary screw Air compresor. We ordered a new control panel for the unit because the old panel had a burnt resisitor. The new panel was installed and wont start the unit...
First you need to program the controller. Controllers do not come programed for a specific compressor. You will need to enter factory set point and and set all parameters. Horse power, pressure, DOL start or wye delta start etc. The new controller is probably set incorrectly. Look at factory set points on the old controller and copy all the parameters and then set the new controller to those set points.
Sep 06, 2010 | Ingersoll Rand Stationary Air Cooled...
Oct 21, 2009 | Ingersoll Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Cant set my compressor to automatic start/stop mode
Sorry, what do you mean it 'blows off',, the relief valve is letting off pressure ? Sounds like you need to replace it with the proper psi Relief valve or just a new one. Then you say it restarts but in your question you say 'Cant set my compressor to automatic start/stop mode' If it is restarting that means it is automatically 'stopping' then automatically 'starting' Please clarify your question.
Nov 12, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ingersoll Rand Horizontal Electric Air Compressor 25 Hp, 120 - Gallon, 460 Volt, 3 Phase, ModelNo. 81295107 Logo
272 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
