Question about Kodak EasyShare V1003 Digital Camera
Lcd is too bright - Kodak EasyShare V1003 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
There's an option in the Setup menu titled "LCD Brightness." Press the Menu button, use up/down to highlight Setup, then press OK.
Posted on Jun 04, 2010
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
Mar 25, 2010 | Acer 22" X223w LCD Monitor
LCD NOT VISSIBLE BRIGHT
Good afternoon!
It sounds like either the LCD inverter, or the LCD back light, has gone bad. If you want to try to replace these items yourself, please follow the lick given below for pictorial instructions on how to do this.
http://home.comcast.net/~nw_systems/vgnBX.pdf
Best of luck and have a good day!
Ron
Jan 06, 2009 | Sony VAIO VGN-BX540B Notebook
Glaring nothing but bright can't see the picture
Try to adjust LCD Brightness.
Press Menu.
Go to LCD Brightness.
Dec 09, 2008 | Samsung Digimax D53 Digital Camera
COMPUTER LCD BRIGHTNESS
go check your model # brand , and try to reemplace a LCD LIGHT DISPLAY INVERTER, it should be a small light bulb located inside of your lcd laptop
Dec 03, 2008 | Computers & Internet
Want to change LCD brightness on Clock Radio
you could try to internally change the brightness, but unless you know a lot about circuits, I wouldn't mess with the internal wiring.
Nov 12, 2008 | Audio Players & Recorders
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
LCD brightness question
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
