Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
I have a Waterly Executive Pump PF-40-2N22C\r\nI
I have a Waterly Executive Pump PF-40-2N22C I need a part for it. It is the plastice cover with a 2 inch male thread and
has 8 screws holding it to the body. It got cracked due to ice buildup.
    Habit-Forming:
  • 77 Answers
Waterway did change the wet ends slightly (the difference is only minute and you wouldn't realise without meausring) and if yours is the older version you may need to change the entire wet end.
I'd advise you to take the pump to someone who can advise you and perhaps consider changing the entire wet end so that you have a new mechanical seal too.
If you're in the UK I can possibly help but I suspect that you're in the US...
http://hottub.synthasite.com
Regards,
Ian.
Posted on Jun 18, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Need to change the seal on a PF-50-2N22C
Thank you for posting your question here on Fixya.com.
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order. If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 03, 2011 | Waterway 5HP Executive 56 Frame Spa Pump...
Propeller is stuck, how do I free it up?
remove pump and wet end from spa
remove outer cover of wet end (small screws)
the impeller will be exposed.
remove any obstructions and then free it up by turning it
if it wont turn motor may be seized
replace cover, etc.
Sep 12, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
I have a waterway mustang 56 pump. Pump just hums but does not start up.
check the capasitor under the small cover on top of the motor look for bad wire or swelling anywhere on the capasitor the motor will not start if it is bad
Aug 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Can't get the pump apart to replace leaking seal.
if seal has been leaking probably ruined motor just replace whole pump and motor
Jun 24, 2010 | Waterway Executive 56 Spa Pump 3hp 2" 2spd...
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
My wet end is leaking from the backside.
I have a executive 56 frame 4 hp water way motor - PF-40-2N22C. Wet end was leaking at shaft, had it fixed and now the motor won't rotate at all. shaft is free it just hums. Checked supply voltage and the voltage at the connector. All is ok, what do i do now.
May 21, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
813 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
