Question about Acer TravelMate 4230 Notebook
Laptop won't boot turns on then off after about
Acer travelmate 4230 Laptop won't boot turns on then off after about 10 secs. Pulled everything off including lcd screen
    Scholar:
  • 92 Answers
Your Laptop seems to be full of dust - Maybe your CPU Heat sink FAN cannot turn because if this THUS causing your laptop to heat up and shut down again to prevent your CPU from receiving damage due to high temperature.
Close your laptop lid, then put the unit on its backlcd. Make sure you disconnect the Battery and the A/C Power chord. With the emty battery slot is facing you, take note of the screw that is facing you to the right on the bottom cover. There might be others like this in the same area. The cover that you need to remove is of rectangular shape, and the largest cover.
When you have removed it you should see the CPU Heat sink and a FAN. This is the part where you blow the unit out at that spot with compressed air so that the dirt will no longer block the heat from venting away from the laptop mainboard/cpu.Please check if the CPU FAN is still turning licenly. If it doesn't turn or very difficult - replace .
[ADVANCED]
Then, remove the 3 screws from the CPU heat sink and thereby remove the HEAT sink completely. Remove the CPU Heat sink FAN and clean it as nessesary. Use a small flat to switch the CPU from closed to open and remove it. Then clean it with a cloth and ethanol - make sure you remove all dirt and old heat sink paste on top if it. make sure you do not touch the bottom of the CPU and handle the pins carefully.
When you are done, place the CPU back and reaaply a eyedrop of fresh heatsink paste onto the CPU, lock the CPU switch again. Then clean the backside of the CPU heat sink where it rests on the CPU. When you are done with that, place the CPU heat sink back onto the CPU then screw the 3 screws back onto the CPU heat sink and onto the mainboard. Keep the sequence in mind. Reconnect the CPU Heat sink FAN to power on the mainboard with the cable then place the cover back onto it. Tighten all screws again and reconnect battery and A/C Power chord.
Posted on Jun 04, 2010
How to giving boot with different ways to acer travelmate 2423 laptop
1) You can set your boot options in your bios, watch as you laptop boots, you should see something like "Hit F2 to enter setup". Hit F2, select boot options then choose to boot from CD, HDD or external drive. Take care because you don't want to mess up your Bios. So read the screen carefully before changing anything. When you're happy, select save and exit then reboot, you should then boot from the device of choice in the order of choice.
2) Windows boot options, windows has several options for booting from, including safe mode. To do this, hit F8 several times while the laptop is booting, you should come to a screen with the several options on offer.
Feb 12, 2012 | Acer Computers & Internet
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Mar 16, 2011 | Acer TRAVELMATE 5730-6984 LAPTOP LCD...
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
Blank screen on my acer laptop, it boots up, and i have put it on an external monitor, and it brings the screen up on the laptop,also tried changing the screen from 1 to 2 so the lcd is not broken, tried...
If an external monitor works fine then maybe you're having issues with the LCD's backlight. It happened to my laptop and I had to replace the whole LCD itself.
May 11, 2010 | Acer TravelMate 7120T (91.42A01.605) PC...
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
My acer travelmate 4150 when switched on makes a constant screaming noise and does not boot up
Try this: once you turn on your Acer Laptop, immediately it shows the acer logo on your screen, press 'Esc" button constantly or press the "Esc" button continuously immediately you turn on your laptop.
I am telling you to do this out of experience, but if it does not work, let me know.
Take care.
Dec 08, 2009 | Acer TravelMate 2300 Notebook
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Acer Travelmate 2410 with display probs
Could be the screen is running with the wrong colour depth and resolution - reset the settings by right clicking on the screen selecting properties and then adjust on the settings tab.
Mar 10, 2008 | Acer TravelMate 2300 Notebook
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer TravelMate 4230 Notebook Logo
536 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
