Question about Maytag MDE9700AYM Electric Dryer
No Heat / Low Voltage I bought the dryer 7-8 months ago. Dryer runs (everything) EXCEPT no heat. Have tried all cycles: nothing Opened the dryer up, am using the 'troubleshooting guide' from inside. Diagnostics show F31 (low voltage) Got out the multimeter... I have checked: Circuit box, wall outlet & power cord: all 120/240vac I have checked: relay connections on electronic control, Thermal Cutoff, High Limit Thermostat, and Heater Element: all have zero resistance What else could be wrong that I can check?
  • Maytag Master
  • 19,396 Answers
Hi.
F31 means low voltage from main. Thermal Cutoff, High Limit and other internal parts cannot trigger the problem.
I think this dryer does not have a power board with relays either than control assembly.
The only internal parts that can cause the problem are control assembly and wiring to power cord.
Double check to ensure that the problem is not low voltage from line or power surge, then inspect wiring harness to power cord, and eventually replace the control assembly.
Since the problem is quite unusual, also call Maytag to check if they are aware of any related issue (F31 when line voltage is OK).
Here the parts and diagram.
Regards.
Ginko.
Posted on Jun 04, 2010
  • 7 more comments
  • gstoner Jun 04, 2010
    Went through the 'saved diagnotic codes' all 4 saved codes are F 31
    Then performed the "Line Voltage Test" listed in the troubleshooting guide. Display momentarily blinked at 1 20, then straight to 2 45...and the drum started to spin. Drum continued to run and display stayed at 2 45 until power button pressed.
    "Double check to ensure that the problem is not low voltage from line or
    replace the control assembly."
    -done, nothing wrong that I can tell (visually or electrically) except for replace the control assembly.
    Would the F 31 code prevent the heater from working? I tried the normal power on cycle, drum spins, all indicators are good, no heat felt inside drum after 3 minutes.
    Could the heater coil itself have burned out or broken, leaving all of the sensors intact?
  • Ginko
    Ginko Jun 04, 2010
    Re:Would the F 31 code prevent the heater from working? I tried the normal
    If F31 is displayed, yes. The timer board will stop. After resetting the code the machine will start and cycle until the F31 code is shown.
    If the F31 is shown at start, then there is either a voltage problem, or a faulty control.
    The heater coil (the heating element in the electric dryer), can be easily tested by disconnecting terminals and ensuring that there is continuity (circuit not open). A blown element will leave circuit open.
    When element is blown the machine will still operate without producing heat.
    Can you please confirm that the model is
    Maytag MDE9700AYM, I will have a look at the service manual on this.
  • Ginko
    Ginko Jun 04, 2010
    Hi. On Maytag MDE9700 series electric dryer, wrong voltage should be error FE, there is no F31 listed.
    F31 is wrong voltage on several Whirlpool built dryers.
    Please check that we are talking about the same model.
    Thanks
    Troubleshooting guide is P.N. W10258376A, error code list on page 3, F 31 shown only in 'diagnostic mode'
    L2 shown in normal mode (turn dryer on for normal cycle, everything runs except heat, L2 flashes)
    Model: MEDE300VW1
  • Ginko
    Ginko Jun 04, 2010
    Thanks for the model number.
    Effectively F31 is a wrong voltage error. It can be caused by bad line voltage, ground problem, loose ground cable, and faulty control.
    Is it possible to connect the washer to a different main using an extension?
    PS:I will be out for about one hour.
    It is the same outlet that was used for the last 11+ years for the dryer. Present dryer has been running fine for 4-5 months before problem was discovered. [background history]
    Another main? only have one 240 in the house, other 240 is for water heater underneath with it's own box. or something different? main box only has one 240v breaker for dryer (stacked / one piece double 110)
    Since the dryer is 'seeing' 245 VAC, could the voltage be too high? and if so, what could cause it to jump up?
  • Ginko
    Ginko Jun 04, 2010
    The pint is that there are no much component between the main, power cord and the transformer on control board:
    The only think I can think of is jumping the door switch, even if I think that door switch causing this code is quite unusual. The problem is either AC power from line or the control board.
  • gstoner Jun 05, 2010
    Not sure what I did, but the Dryer now works. Tried everything you had mentioned, and figured that I would try to run it in normal mode. ran the dryer for 2 mintes, checked inside and it was warm. So far has dried 4 loads.
    *shrugs* I wish I knew what changed, so that I can make sure it doesn't happen again...
    Thanks for all your help :)
  • Ginko
    Ginko Jun 05, 2010
    Hi.
    If the fix happened randomly it is either a wiring problem, or the electronic control was jammed with some loaded capacitor helping the problem to persist after disconnecting.If problem is a jammed control, then the board components get definitively discharged by leaving power disconnected for a couple of hours. The electronic boards may also work erratically because of a "cold solder joint", that is a bad contact in the printed circuit board. This is also a problem that can start and stop by itself with vibration. Cold solder joints are tested reading Ohms in pcb circuit from contact to contact. A lose ground wire could have also caused the problem. If problem was wiring or cold solder joint , it may happen again.
    Regards.
    Ginko.
What could be causing my dryer not to put out heat on certain cycles?
Everything points to the timer even if you replaced it once. Low voltage or bad ground could be stressing your timer out causing it to malfunction. Make sure all power connections are tight all the way back to the circuit breakers.
Oct 03, 2014 | Dryers
Whirlpool Dryer IED4400SQ0 wont heat
Check your thermal fuse and the thermal cut-out fuse, two different fuses that can cause a dryer to run and not heat when open, or some dryers will not start when one of these has gotten too hot and opened....Usually caused by venting restriction of too much lint, common problem...........
A open operating thermostat or the high limit being open are also possible........;.
The other checks are live voltage checks, timer contacts, wiring, temp and internal motor switch......schematic is probably in back of control panel........
Takes some reading of a wiring diagram, understanding how to split the circuit ............Not for beginners.............Hope this helps...........do not forget to unplug dryer when doing anything on unit besides live voltage checks on circuits,,,,,,,,,,,,,,,
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Maytag MDE9700AYM Electric Dryer Logo
430 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
