Machine stop washing after prewashing and on the display appears A-4
  • penckor Jun 06, 2010
    LDF12314 hotpoint ariston
  • Washing Mach... Master
  • 19,396 Answers
Hi.
Can you please tell us make and model number of the washer, so that we can tell you more on the error code.
Thanks.
Posted on Jun 04, 2010
  • Ginko
    Ginko Jun 06, 2010
    Hi.
    Fault code A4 means: Unable to reach or sense the water temperature within 70 minutes.
    If there is no heat, then you have a faulty heating element or a wiring problem. If the water is hot, then you have a faulty thermostat.
    Element and thermostats can be tested by removing them from appliance and reading Ohms at their terminals. Thermostat must read low or zero impedance at room, element must return continuity (circuit closed. Thermostat can also be tested jumping its terminals to bypass the thermostat.
    Here all trouble codes, scroll down to LCD dishwashers.
    Regards.
    Ginko.
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
What does F-11 indicate? Washer stops and door
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Apr 08, 2010 | Kenmore Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Hotpoint wma34 stops and prewash light flashes
I would check the water pump for a blockage a button or other debris may be lodged in there preventing it for operating properly eric
Jan 15, 2018 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Jun 06, 2006 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
490 people viewed this question
Top Washing Machines Experts
