Question about Carrier 52CE-309 Cool Electric Heat Air Conditioner
Carrier 52MQ series PTAC. Set dipswitch 4 to ON
Carrier 52MQ series PTAC. Set dipswitch 4 to ON (UP POSITION) in order to cycle the fan for use only when compressor is running. Fan runs 24/7 and won't cycle??
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Posted on Mar 09, 2009
  • 148 Answers
SOURCE: UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
Posted on May 03, 2009
manhandy
  • 146 Answers
SOURCE: my carrier 38BRC024310 is not running outside.
some do have one, but i would check if you have burnt out fuse should be right next to the unite or a blown circuit breaker
Posted on Jun 24, 2009
SOURCE: 24ABR348A0031010 compressor starts then stops.
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Posted on Jul 15, 2010
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
It keeps freezing over (even at the low mode on cold and the temperature is set all the way to 80) the whole system freezes any help will be great thanks guys
The unit most likely has a refrigerant leak. This will cause the system freeze up you describe.
The leak will have to be found, repaired, and the system recharged. Depending on where the leak is the cost for total repair could be more expensive than you want to spend. Compare with cost of a new unit.
Hope this helps.
Sep 13, 2011 | Carrier 52CQ-212---4 Comfort Series Heat...
Carrier 52CQ-207 not heating
heat pumps are a very complex with many varables it would be best to let a tech come out a look at this for u as there are not alot of serviceable parts thanks
Mar 15, 2010 | Carrier 52CQ-207---3 Comfort Series Heat...
FAN MOTOR CONTINUES RUNNING AFTER HEATING CYCLE IS COMPLETED BLOW
Check the thermostat. Make sure it is set for AUTO fan not ON fan. If that is OK replace the fan relay.
Apr 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
GE PTAC AZ38H09DABM2 WENT DEAD..POWER OK
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
Carrier 52S PTAC heating problem.
Sound like a froze contactor on the board.
Nov 25, 2008 | Carrier Heating & Cooling
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Carrier 52CE-309 Cool Electric Heat Air Conditioner Logo
234 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
