Question about Saeco Aroma Espresso Machine
I need the electrical scheme for a saeco aroma nero sin 015. Can anybody help me with that? Thanks
  • 74 Answers
SOURCE: Need a repair service
A aroma is very easy to open up so if you can find a erpair station near you i would suggest you to fix it your self.
open it up and reset the fuses there is one on the top of the boiler when you open it up.
Then you need to prime it.
Turn it on ( as this should work now)
open up the steam valve and then press for making of a cup of coffe. this hould prime the machine though the steam nossle.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: Saeco Aroma Espresso Machine.....doesn't draw water.
You have to take a bellow pump or similary and fill with water, after that you have to open the steam knob and put force in the water from the bellow pump into the water inlet on the machine.
Hope this will help you, let me know if it works.
/Mirran
Posted on Aug 16, 2008
SOURCE: saeco how to reset
called saeco helpdesk and with their assistance found the reset button inside the machine (open the top with a screwdriver). there are three termostates. on the middle one there is a button. when you push it you hear a metallic sound. then you have to close everything and put it on again.
how to avoid this problem: it is important that there comes no air into the heater. So you have to watch the water supply carefully and leave the air out from time to time.
Posted on Sep 16, 2009
  • 1089 Answers
SOURCE: No steam on saeco aroma redesign
Hi
That is probably you steam thermostat. Its a 127c thermostat.
Posted on Oct 28, 2009
SOURCE: need saeco sin 006 manual (english)
Here you go:
http://www.partsguru.com/SaecoRioProfi.html
Posted on Nov 01, 2009
Saeco interchangeable parts
look on the model plate and see who made it
n contact them on the net and see what is available.
May 15, 2015 | Saeco Coffee Makers & Espresso Machines
The steam light on my Saeco Aroma does not turn on (and no steam comes out), even after the brew light turns on and I press the steam button. How can I get my steam to work?
HI
It is probably your steam thermostat that needs to be replaced. There are 2 thermostats. The Brew and steam. If one of them fail it won't heat the boiler for that mode. They are easy to replace.
Oct 05, 2010 | Saeco Aroma Espresso Machine
Hi
Oct 27, 2009 | Saeco Aroma Espresso Machine
Saeco aroma compact SE 2GR turns on, but only heats the water.
I had replace my on off rocker switch on my aroma nero after a couple of years I was able to swap out my switch for heating the steam as a temporary fix I purchased a replacement switch from Sacco at that time but I think now you might have to go to a secondary parts dealer I have kept this machine a live for over 12 years and am now going back to it after fighting with my new automatic machine sure it was easy but the taste just was not the same the kids can have it they put so junk in their coffee how would they know pbjh2o@yahoo.com
Sep 05, 2009 | Saeco Aroma Espresso Machine
Saeco Aroma steemer spit out a lot of hot water
This is normal. The solution is to let the steam wand run for a few seconds to purge all of the liquid water from the system before you begin steaming your milk. It will take about 10 seconds or so. You can do it into the drip tray, into a pitcher or bowl, onto a rag, or even on the counter. The key is not to put your milk under the wand until all of the liquid water is gone and all that is left is steam. Good luck!
Feb 28, 2009 | Saeco Aroma Espresso Machine
/Mirran
Aug 16, 2008 | Saeco Aroma Espresso Machine
Steam nozzle leaking
Hi! hope i'm not too late, since this leaking problem occur's quite often, specially when one's tends to overtight the valve, the proposed solutios will certainly help thousand of happy Saeco owners.
Anyway i happened to live with it but after a second valve replacement, i got fed up with filling too often the reservoir and fixed it at Zero cost. What i did is realy easy:
1- Find a bearing the size of the plunger of the needle valve; the thiny steel ball in a nail polish bottle is what i used.
2- When the electric cord is pulled off the wall outlet, take the cover off, reach to the snap locker and pull it off.
3- Unscrew the needle valve plunger off the cylinder, grind or file the
tip 3/16 of an inch, making sure it is at rite angle cut.
4- Insert the ball in the valve body and push it with the flattened tip
over the vapor down stream and screw. You now have a new valve that will outlast your coffe maker.
Aug 04, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso pump not drawing water
Hi Espressoless,
You have to force in water to the machine, to this you need a bellow pump or similar and force it into the water tank inlet when you do a priming.
Dec 30, 2007 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
192 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
