Question about Vacuums
Shutting off my vacuum has been shutting off in middle of use and i dont know why its like its over heating and i cant use it again for almost an hour is there a solution to this? or do i need to get a new vacuum?
    Champion:
  • 207 Answers
It has a built-in temperature sensor which prevents it to be damaged from overheating. That's why it shuts down. It just needs to be opened up and cleaned thoroughly. Start with the hose if it has one and let someone who is handy with electric appliances to open it's casing and clean the insides.
Posted on Apr 09, 2008
Is there a reset button after allowing to cool down
There may be a reset for the Power nozzle motor. The tank does not have a reset. Did the whole machine or just eh tank shut down? What caused it to over heat, do you know?
Feb 27, 2015 | Kenmore 25512/ 25513 Progressive Canister...
Vacuum shut off in middle of use
Yup....it has overheated because of the jam and might take serveral hours to reset.
Dec 03, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Why is my carpet cleaner over heating
pump needs replacment how do i replace it
Apr 06, 2013 | Rug Doctor Mighty Pro Blue MP-C2D
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
I have a Hoover self propelled WindTunnel vacuum( Model U6425-920) that stops in the middle of cleaning. I have changed the flat belt and I'm still experiencing the problem. I usually have to wait an...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632298
Generic problem for all Vacuums
Posted by thjunk2007 on May 29, 2008
I have a Hoover self propelled Windtunnel vacuum( Model U6425-920) that stops in the middle of cleaning. I have changed the flat belt and I'm still experiencing the problem. I usually have to wait an hour or so b/4 it would work again. Any advice?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Orange light is on
You may have a clog, which over heated the motor and it shut down. Clog could be in the hose, the dirt inlet by the brush roll and bag/filters. Some have a reset on the back, near the bottom. If not, then the over loard protector may have gone bad, could also have a motor problem.
Mar 22, 2008 | Royal Procision 7050 Bagged Upright Vacuum
Vacuum stopped in middle of vacuuming our carpet. Would not startup at switch. Tried other electrical outlets wondering if this was the problem and checked breakers, but it still did not go back on.
2 guesses.... One is that you vacuumed up a pice of cord or sting that got wound up on the roller (if it's that tyme of machine, and NOW everything's completelt "loced." Cure: look at the brush roller and "unwind" the cord or string.
Two is that you were doing it for a long time and the thermal circuit breaker (which is IN the vacuum cl;eaner itself) over heated and cut out. Usually these are self-resetting, so in a 1/2 hour or 45 minutes - when the thing coold down, it'll start working again.
Note that my first suggestion COULD cause the motor to heat up the and cause the thermal cur out.
Mar 17, 2008 | Vacuums
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Vacuums Logo
183 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
