Question about Whirlpool GGW9200L Gas Dryer
Dryer reset? The dryer started up then stopped. No lights at the control panel. Have power at the receptacle. Is there a reset button somewhere on the dryer?
    Novelist:
  • 184 Answers
NO RESET BUTTON, BUT THERE IS A THERMAL FUSE LOCATED ON THE BACK NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED TO IT. CHECK FOR 120 VOLTS AT THE TWO TERMINALS. IF YOU HAVE 120 VOLTS THERE, THE THERMAL FUSE IS BAD. REPLACE FUSE AND CHECK FOR RESTRICTION IN THE AIR FLOW. ALSO, IF YOU HAVE A THERMOMETER THAT CAN MEASURE TEMPS BETWEEN 100 AND 200 DEGREES, CHECK THE TEMP AT THE EXHAUST ONCE THE DRYER IS OPERATING AGAIN. IT SHOULD CYCLE OFF SOMEWHERE AROUND 170 DEGREES. IF IT GOES OVER 200 DEGREES, REPLACE THE CYCLING THERMOSTAT.
Posted on Apr 10, 2008
Dryer stops
Unplug your dryer plug. Go to your house electric panel, turn off your 30 amp dryer breaker, and then turn it back on. This resets the breaker. So before opening up the dryer to look for fuses, make sure you have power at the receptacle. Don't plug anything into the receptacle until you have wired it correctly. If you want to run it by me when you're wiring it, that's fine with me. . I hope this helps. Good Luck! Jim
Mar 16, 2010 | GE DBSR453EBWW Electric Dryer
My whirlpool dryer will not start when I hit the start button. There is no noise and it has power.
This sounds like it is a bad control board. But try resetting the system. To do this just unplug the dryer from the wall for 15 minutes. Plug it back in and see what happens. If nothing happens then you have a bad control board.
the other thing that you can check is for a bad fuse. You will need to remove the back panel where the power cord goes into the back of the dryer, there you will see a control board with a fuse. Make sure that is not blown.
Jan 02, 2010 | Whirlpool GEW9200L Electric Dryer
The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Aug 27, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer stopped- not fuse
are you sure you have power to unit? first check for 240volts @dryer receptacle,then you could have either power wires or the neutral wire inside dryer burned off or broken, if it has an electronic control panel there is an electronic protection fuse to protect controls from surges
Aug 24, 2009 | Dryers
Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Apr 10, 2009 | Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer died
Hi! kiatt28
According to the manufacture (Whirlpool manufactures this model for Kenmore) PF is Power Failure, they do not recommended replacing the control. Have an electrician check the wall receptacle or breaker panel. I suspect you have a loose connection, sometimes it is just time to replace the receptacle.
InMrFixIt
Aug 09, 2008 | Kenmore Elite HE4 Electric Dryer
Drum light works - contol lights don't/can't start dryer.
Either the machine control, or the user interface. Further diagnosis isn't possible. I'd try the machine control first. It's just under the top panel, along the left side.
Feb 06, 2008 | Whirlpool GEW9250 Electric Dryer
My dryer doesn't run
If the dryer doesn't start or make any noise: 1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be aware that most electric dryers don?t plug into standard 120-volt receptacles?they operate on 240 volts. Make sure the door is closed completely, the timer is advanced to the proper position, and the correct cycle is selected. 2) If the receptacle is dead, check the circuit breaker or fuse that serves that circuit. 3) Unplug the dryer and check the power cord and the terminal block. If necessary, replace the cord. 4) Open the door and check the door switch. Press and release it: it should click each time. If it doesn't, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service. 5) If the dryer still doesn't work, a thermal fuse or other electrical or electronic parts may be faulty. Call a service person.
Jan 18, 2006 | AEG T57800 Electric Dryer
Whirlpool GGW9200L Gas Dryer Logo
124 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
