Question about Dryers
I am installing a ceiling fan to replace a ceiling light. The wiring up there is old. Three red are twisted together and live. two black are twisted together and not live. One futher black is by itself and live. Turning on/off the wall light switch does not change what is live. The fan expects live / neutral / earth. How should I wire this please.
  • A Miller Jun 04, 2010
    Consider the light you removed ... it was a simple on and off? Make the same connection with your new light/fan. There should be a white there somewhere. It worked before and you have not really changed the switch nor the way the wires were connected. If you connect the fan like you disconnected the light, it should work. Or was the light operated by a pull string??? Now that I havd said all that ... we are talking about 110 VAC - right??? The presence of a red would indicate a a out of the ordinary situation ... extra circuit or switch leg or three way switch.
  • 391 Answers
You should hire an electrician.
Posted on Jun 04, 2010
We are wiring a new ceiling fitting our old rose has two black wires two red wires and two earth wires new fitting has just three wires how do ee wire this up to stop it blowing system
Twist the current pairs together and then twist the white (neutral) to your red pair, the black (hot) to black, and green (ground) to green.
Dec 07, 2014 | Dryers
Box in ceiling has black wire and white wire & the ceiling fan has white wire, black wire and red wire.
BEFORE YOU PERFORM ANY CONNECTIONS BE SURE THAT THE CORRECT CIRCUIT BREAKER FOR THE BOX HAS BEEN TURNED OFF! You must check for voltage between the white and black wires at the ceiling box with each of your two wall switches toggled up or down ONE AT A TIME!
The green wire in the ceiling box (or bare copper wire) is your ground wire and should be connected to the green wire of the fan, and also should be mechanically connected to the electrical box by a screw or clip. If your system was wired correctly you should find that it already is connected to the box.
The white wire in the ceiling box is your neutral wire, so any and all white wires from the fan should be connected to it. You may have one for the fan motor and one for the light kit if there are two separate whites from the fan. Again, they may already be connected together in the fan/light assembly.
The black wire in the ceiling box is switched on and off from either of the two switches in the room, which I assume are located near two different doors to the room. These are called "three-way switches". They are not marked "on" and "off" on the toggle like any single-light switches in your home. That is why you must check for power at the ceiling box with the switches in each position one at a time to make sure that the circuit is de-energized.
Now for the connections:
You will need to connect both the red and black wires from the fan to the black wire from the electrical box. The black wire in your ceiling box is your "hot" wire and will provide power to both the fan motor (black wire) and to the light through the red wire--(sometimes this wire is blue, for others who are following this post).
With this arrangement, your fan and light will only operate with one or the other of your three-way switches completing the circuit from your breaker box. You will have to use the pull chains on the fan to control the fan and lights. So you will probably want to leave the light "pulled on" so that you can control the room lighting from either of your three-way switches, and operate your fan speeds from the pull chain. However, if you want your fan only on at night you will have to "pull off" the fan's light switch.
You may find all this switch flipping and chain pulling an inconvenience. If so, hire an electrician to install wiring so that the ceiling box will be "hot" all the time to the fan's black wire and the fan will therefore be operated by the pull chain only, and the light kit will be controlled by either of the three way switches, via the fan's red (or blue) wire.
One other caveat before you begin: you must make sure that the ceiling box is rated for and mounted sturdily so that it will support the weight of the fan and light kit. Many ceiling boxes are designed and mounted to support only a light-weight fixture. You don't want your fan to come crashing down from the ceiling!
Oct 15, 2012 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Installing remote control ceiling fan
Your black wire is line and red is load. So your incoming power hot goes to black and out going power to fan connects to red. White is wired with all three whites together and same with green.
Aug 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
