Question about HP Photosmart C6180 All-In-One InkJet Printer
Vertical lines on photocopies and scans
Have cleaned the white document plate and the base plate. Did not solve the problem. The manual tells me to clean the glass below the document feeder but I cannot open it!!
  • 128 Answers
Dont try your self, as u would be some other trouble, this problem seems to be of your drum , get some techinicall person to do repair it
Posted on Jun 04, 2010
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
When I make a photocopy I get a dark vertical line down the page. In fact, now I get two dark lines. It has something to do with the scanner, because it happens when I send someone a fax as well. ...
Do you use the automatic document feeder (ADF) when you photocopy and fax? Do you use the platen (lift the cover up) when you scan a document? If so, you probably have some dirt or foreign material in the ADF scanner area, which is a thin glass area to the left of the glass platen. Clean this area with a damp cloth and dry it before trying again. There is a plastic strip covering this area, and if this is scratched it can be removed and replaced.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Vertical line appear on my HP OfficeJet J 6450
Look at the narrow glass and see if there's white out or anything on it, also the white reference guide above the glass needs to be clean as well. The skinny glass under the adf is where documents are scanned when not placed on the big glass.
Jul 31, 2009 | Office Equipment & Supplies
Vertical line appears with APF
Open the ADF cover and clean off the narrow scan glass (most likely has white out on it)
Jun 03, 2009 | Canon imageCLASS D680 Laser Printer
Problems
Assuming the the Glass is cleaned-  and the device is mechanically functional- then the only other thing to go wrong is the CCD- the image capture device- at that stage I suggest there is no repair feasible only replacement of the whole unit.
However a trawl of the Visioneer Web site/customer support may  give a clue.
Oct 10, 2007 | Visioneer One Touch 9450 Flatbed Scanner
HP Photosmart C6180 All-In-One InkJet Printer Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
