Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mitsubishi Model wt-a42
My tv shut itself off and wont turn back on. When i press the tv on the green light stays on for a second then blinks three times and turns itself off. Please help!
    Sergeant:
    Champion:
  • 346 Answers
Change the1000uf capacitors
Posted on Nov 16, 2008
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi model WT-A42
maybe theres aproblem between the power supply and in the horizontal circuit of your tv
Jul 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
TV Shutdown
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
Sep 26, 2007 | Televison & Video
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
301 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
