Question about Dell 1710n Laser Printer
Paper jam dell 1720dn printer
I ran out of paper, refilled the paper tray, made sure there wasn't too much in there--I thought. But when it resumed printing the article I'd sent, it curled one side of the new paper then jammed. Now, I can see the piece that's in there when I lower the door at the back for the barely 45 degrees the darned thing will drop down (I'm afraid I'm going to snap it off!), but I cannot get the paper to feed through NOR can I get enough hold on the paper to pull it the rest of the way through. I haven't printed 100 pages with this thing!
  • Anonymous Feb 27, 2009
    200 Paper Jam
    Remove Cartridgeesto sale en la pantalla de la wede de la impresora...que solucoin tiene..??
I have taken the toner and the drum out to find a paper jam and could not find anything. I even turned the printer "off" and "on" and the "paper jam" light stays on. What can we do?
Celeste
Posted on Aug 06, 2008
  • 1 more comment
  • keithle Oct 26, 2010
    Take the toner cartridge and the drum out. Look at the bottom of the inside of the printer, about half way up, and you will see a little piece of plastic that sticks up. This must move freely. The one in my printer was knocked to one side. Luckily it snapped back into place. If this little plastic piece is messed up it will cause the printer to show a paper jam when there is no paper jam. This information came from Dell Tech Support. Once the little plastic piece was back in place the printer no longer indicated a paper jam when there was none. Be careful, the piece appears flimsy.
    Now if I could just stop the real paper jams.
  • nechlaw Feb 23, 2011
    omg this totally was my problem! it fixed it too. the little black piece was sideways and it popped back into place. thank you.
  • sandy_colato
    sandy_colato Nov 30, 2012
    Thank you so much. You saved my day. Just a little thing can cause a serious problem.
Another place where the paper can get jammed: take the paper tray out completely there is a blue curved plastic that is used to feed the paper back to the printer (when printing duplex) there is a small handle on the left side you can pull down and take the paper out.
i couldnt print any duplex, the paper always get jammed there, maybe the paper used is too thin..?
Posted on Aug 12, 2010
Take the paper tray out of the printer....on the bottom of the printer is a little arm that has 2 wheels with "rubber bands" on them. It sounds like you need to replace them. You can try turning them inside out and that might temp. fix your problem. All the 1700 series printers where I work curl paper all the time and it is because those rubber bands have worn out.
Posted on May 02, 2008
    Problem Solver:
  • 7 Answers
Great i turnd the rubers around and bingo thank you
Posted on May 16, 2009
4 Suggested Answers
  • 105 Answers
SOURCE: curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Posted on Mar 27, 2008
jell587
  • 447 Answers
SOURCE: 1720dn error light will not reset
Follow this link to a previous FixYa post about this error and the suggested solution.
Posted on Feb 23, 2009
SOURCE: My Dell 1720dn constantly has paper jams. A
here's one for you. if it is jamming with one sheet almost out (the trailing edges is just out of the fuser. it will also jam the same way everytime. you might try a different brand toner cartridge. I have beening fixing several with this.
Posted on Mar 30, 2010
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
I have a DeskJet 5940 which was about to be thrown away and I thought I'd have a go fixing it. I tried, but it simply won't work. When I print something it pulls one paper nicely from the tray, feeds it...
  • Reset the product
    1. If the Power light is on, press the Power button (c01346625.gif ) to turn the product off, and then continue with the steps. If the Power light is off, go straight to step b.
    2. Unplug the power cord from the wall outlet.
    3. Plug the power cord back into the wall outlet.
    4. Press the Power button (c01346625.gif ) to turn the product on.
    5. If any lights are still blinking, service the product.
  • If the print-cartridge status light stops blinking after you reset the product, follow these steps to make sure the driver settings are correct, and then try printing again.
    1. Open the printer driver.
      • Windows 2000 : Click Start , point to Settings , and then click Printers .
      • Windows XP : Click Start , click Control Panel , and then click Printers and Faxes .
      • Windows Vista : In the Windows taskbar, click the Windows icon (c01364735.gif ), click Control Panel , click Hardware & Sounds , and then click Printers .
    2. Right-click the icon for the product, and then click Printing Preferences .
    3. Click the Paper/Quality tab.
    4. In the Paper size: drop-down menu, click the appropriate paper size.
    5. In the Paper type: drop-down menu, click the appropriate paper type.
    6. Click OK to close the dialog box.
    7. On the product, press the Resume button (c01421637.gif ) to continue printing.
    Also Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
  • Dec 17, 2010 | HP Deskjet 5940 Photo InkJet Printer
    What does e073 0003 error mean on canon 1180.
    E, 0, 7
    FINE Cartridge is not installed in the correct position
    E, 0, 3
    Paper Output Tray is closed / Paper jam
    Summary
    If the Paper Output Tray is closed, open it. The machine resumes printing.
    If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
    E, 0, 3
    Summary
    Techbelkin please rate me
    Nov 03, 2010 | Office Equipment & Supplies
    Error e03, but there is no jammed paper
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    E, 0, 3
    Summary
    Techbelkin
    Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Dell 1710n Laser Printer Logo
    6,602 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
