Question about Garmin GPS
Having problems with poi loader cant find csv file to be able to download files.unit is a garmin c31o
  • 4 Answers
Here's how you get custom POI files on a Nuvi:
1. Download and install Garmin's POI Loader.
2. Create a folder on your computer, suggest Desktop, with a name like "Custom POIs". The name and location doesn't matter but you have to remember what it's called and where it is.
3. Go online and look for 3rd party POI files. Places like www.poi-factory.com have dozens if not hundreds of files.
4. Select ones you want on your gps to download. Make sure you are getting the files in the correct format. Newer Nuvis use *.csv files. Not sure if the C310 does. Download your POI files into the folder you created.
5. Plug your USB cable into the GPS and your computer. Wait until the driver finishes loading.
6. Run POI Loader and follow the instructions until you get to a screen asking for location of POI files. Point it towards the folder you created. Next tell it to load the POI files. After a few seconds it should give you a message "XXXX data points successfully loaded".
You should now be able to go to POI/Extras screen and see "Custom POI Files". Open that up and your custom POIs should be there.
Posted on Jan 18, 2009
Custom poi doesn't have Go
connect your gps to computer and look at the files in the poi folder. they should be gpx files. When poi loader does its thing it converts the csv files to gpx maybe something didn't work the last time you loaded files.
Nov 14, 2017 | Garmin Nuvi 1450LMT
How do I get the address data downloaded from the unit to my computer. I have the unit connected to my computer but none of the files look like data files that can be copied or exported?
To get personal Addresses and POI's onto your Garmin unit you will have to use a software called "POI Loader" here is a link to the software.
Hope this helps!
Apr 15, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
I want to go Geocaching and I want to know how to enter Lat/Long or update my equipment to this?
well i'm a great geocacher and i love to help people with the GPS'rs
so you found the guy :))))
It may not be the easiest approach, but you could create a custom POI file for your Geocache locations and then load them into your c330 using POI Loader.
If you're a premium member on Geocaching.com, it's my understanding that you can download locations in GPX format. POI Loader is supposed to read GPX files, but I haven't tried it with geocache locations yet.
Do you have a geocaching account that can download GPX files?
Someone told me that you can use Long/Lat with Google Earth, and you can save Google Earth POI's in GARMIN .cvs format, to use in the PIO Loader.
May 03, 2009 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin nuvi 200 and am trying to update. I am using the
If you are refering a system file update then you should download and use the Webupdater from the Garmin website. The POI Loader should only be used to load custom poi files into the unit.
Mar 14, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
GARMIN 260W
Hi It is more important to know how to add POIs. Here is a simple tip:
1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
Cheers
Feb 13, 2009 | Garmin nuvi 260W GPS Receiver
Unable to send and open data sent to my Garmin GPS from Anquet map. I planned a route on my Anquet map software with wayponits etc but was uable to send it to my gps. I have enquired with Anquet and they...
Currently, the POI Loader only supports CSV files because that is the format that most data vendors support. POI Loader may support additional formats in the future.
MapSource only supports .mps, .gdb and .gpx files. You can save files as .txt files if you wish to use this data in other applications.
Sadly Garmin does not produce any software which can convert .txt files.
However, this maybe possible with GPS Utility. Please note GPS Utility is not Garmin software and Garmin does not support this. Click on the following link for more information:
www.gpsu.co.uk
Oct 13, 2008 | Garmin GPS
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps coordinates
If you are asking to put latitude and longitude information into the C330, no, the unit is not designed to accept that type of information.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
780 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
