Question about Hitachi 43FDX15B 43" Rear Projection Television
Convergence IC? You helped me with this problem before... http://www.fixya.com/support/t285057-tv_blinks_off Can I buy and replace the convergence IC's myself? I'm pretty handy with most things... I can do some basic soldering etc. Thanks, Pete
  • 121 Answers
Yes its a very easy repair just go to this website and order your ic's you get free installation instructions plus free online tech support to talk you through the process which takes about 45 mins start to finish they are located inside chassis on extreme right side on big heat sink just copy the stk numbers off the ic chips and those are the ones you need to order very easy repair
here is a link for you
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
Hitachi Projection TV that has no picture, there is a clicking sound from inside when tv is on. Taking off the rear panel reveals there is a green blinking light on the board that is blinking. Recently...
palmer_band,
Due to the fact that you recently replaced the convergence ICs I would look at that area. Check all the resistors, diodes and semis for any problems. If none are found use my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting to help troubleshoot your unit.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 07, 2011 | Hitachi 46F500 46" Rear Projection...
60pp9753/17 replaced convergence ic chips power light comes on blinks once but no picture or sound. checked power supply slight humming noise coming from the ssb area small red light on the circuit board...
Soldering or bad IC chips...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2011 | Philips 60PP9753 60" Rear Projection...
Had convergence issues, green was okay, red wouldn't move horizontal, and blue wouldnt move vertical. Also, functions such as pincushion and tilt wouldn't work with red or blue. Replaced convergence IC,...
  • Screen looks 3D
Here are some images of convergence problems.
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Mar 06, 2011 | Mitsubishi VS-45609 TV
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Can you help me please
Convergence amp ic bad
Sony Convergence
Jan 28, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Please help super bowl depends on it
Sony Convergence
Nothing Happening
do you get any blinking lights? does it make any noise or clicking?
convergence ic are common problem
Convergence IC's
Sony Convergence
Jan 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
No picture or sound.
replace convergence ic and bad caps
replace DM
Oct 20, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
