Question about Vulcan ERD85 Deep Fryer
Hi, our Vulcan Ultra 15 blows cold air and keeps
Hi, our Vulcan Ultra 15 central heating unit blows cold air and keeps on turning on and off. While doing this, it displays the RESET message on the remote. Help will be highly appreciated in this cold weather. It's not a deep fryer as mentioned below in the Product Box. I selected this because there was no option for the Ultra 15 central heating unit.
bigg t
  • 640 Answers
SOURCE: vulcan 1gr45 deep fryer
The thermopile is bad.You can contact your local hobart service center for the part number.Its a cheap part and easy to put on,any questions let me know.
Posted on Dec 03, 2007
SOURCE: Rival CFZ530 Deep fryer
I had this same problem which is how I came across your post, and I found on the Rival website ( www.rivalproducts.com ) you can email the company and tell them the model number and they will email you the manual, and if you're like me and hate to wait that long, you can call their customer service number and tell them what you need and they will email you the manual in about an hour. The number the website gave me was  1-800-323-9519, and I also realized there was also a number on the box too.
Posted on Apr 16, 2008
IrishDruid
  • 2712 Answers
SOURCE: Deep fryer power cord
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 17, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
SOURCE: Vulcan deep fryer GR-45 Manual
recycle pump
Posted on Sep 08, 2008
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 02, 2017 | Vulcan Heating & Cooling
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Vulcan ducted heating
Do a continuity test on the heating elements, and if they're good then do the same on the sequencers or contactors, whichever you have. The sequencers (or if you have contactors turn on the heating elements). All the fan does is blow air. It blows against the heating element to put out hot air. Either your sequencers/contactor or your heating element is defective.Wait,each sequencers is connected to a fuse.Check the sequencer fuse too. Find the sequencer/contactor wherever the wire feeding the heating element is coming from.
Aug 20, 2013 | Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
I had a vulcan central heating unit that was made in 1990. Could you please tell me what the model number is on a 1990 vulcan central heating unit. Thanks, Rob
Hi Rob, The number you have listed AUW230A may be the model number. You say its a central heat so, If it is a package unit, the model, serial, and all of the ratings would be on the unit near the elect box on a package unit.I do know by the # you gave me it is a Vulcan 3000 watt thermostatically controlled Immersion heater. Here is a link I can give you, they deal with this heater for parts Ect. that maybe of help to you, it is www.grainger.com. There are many model # and I believe this is it, AUW230A. I hope this helps Rob, Sincerely,
Shastalaker7
Nov 17, 2009 | Vulcan AUW230A Heater
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Vulcan ERD85 Deep Fryer Logo
225 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
