Question about Miele Dryers
Miele t294c tumble dryer no heat- have cleared filters and heat exchanger but stll not working
  • SteveEYorks Jul 28, 2010
    Hi, I have the same issue at the moment. Did you get a fix?
SOURCE: Candy Nova CDC 266 tumble
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
Posted on Dec 31, 2008
rogrrabbit
  • 986 Answers
SOURCE: Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 15, 2009
apart4u
  • 213 Answers
SOURCE: dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
SOURCE: how to clean a whirlpool awz7913 condenser tumble
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Posted on Mar 10, 2011
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
Miele tumble dryer t294c moisture sensor what is the part code
Check this site out www.repairclinic.com and enter in your model number you should be able to find the part there .
Nov 24, 2012 | Dryers
My miele tumbledrier ModelT560C makes a noise and sometimes trips the mains. The condenser is constantly wet with no fluff .
Hi - you may have a faulty condensate pump or something to do with this part of the unit - the heat exchanger or condensor will have a certain water residue which should draw off to the pump. In some rare cases the in efficient air circulation causes similar issues to what you are experiencing.
I am unsure about the noise as details are vague - there must be an electrical problem/fault which is serious enough to trip the circuit breaker "mains" as you commented.,
Aug 18, 2011 | Miele T8005 Tumble Dryer
I have a Miele T9800 dryer and it stopped working and the vent/filter check light came on. I checked the filter and vent and both are clear and removed the rear cover and made sure the heating element...
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Jul 16, 2011 | Miele T9800 Electric Dryer
My Miele T294C NOVOTRONIC TUMBLE DRYER KEEPS STOPPING AFTER A FEW MINUTES OF DRYING. I CAN SWITCH IT BACK ON IMMEDIATLY ONLY FOR IT TO STOP AGAIN. CAN YOU HELP?
Hi - it seems likely the moisture sensor unit is faulty, reason?
Well Miele dryers after you start up will actually try to work out the amount of moisture in the dryer, it will calcualte the time & temp required to correctly dry the load in the machine. I suspect the sensor is not functioning proper.
I will assume there are no messages or other indications or flashing lights on the right side of the knob - it would be nice to plug my laptop to it and find out for sure..
You have cleaned the heat exchanger unit in the bottom corner of the dryer, the filter in the door and the two on the bottom of the door opening..
Despite all of these I would lean on the faulty sensor as the most likely culprit.
You may have to locate the nearest Miele service agent to help you out...
cheers
Jun 22, 2011 | Miele Dryers
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
Jan 19, 2010 | Whirlpool Dryers
The machine keeps saying clean out airways yet there is no fluffy stuff on the filters i have hoovered them out as well
Remove all 3 filters, half moon filters below door, filter in door and heat exchanger from front of appliance and rinse under warm water dry and refit.
Nov 17, 2009 | Miele Novotronic T230C Electric Dryer
Tumble dryer borke
Common faults -
Jul 13, 2009 | Miele T8005 Tumble Dryer
Dryer not heating up
Could be the heating element?
Jan 12, 2009 | Dryers
Dryers Logo
315 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
