Question about Amana Heating & Cooling
My heat pump fan will not turn
I went to check to see if the air was working because i noticed the temp went up in the house. I went out to see if the outside unit was running "remote heat pump" and it was not. The motor on the fan was hot to touch and it had a faint buzz. what should i do?
  • 674 Answers
First, with the unit not running, check to make sure the fan spins freely. Next check the capacitor. You can do that with a multimeter or look at it and if it looks swollen then it is most likely bad. Replace it with one of the same rating. If the capacitor is good then use an ohmmeter to check the fan motor windings. Also check the condition of your contactor and make sure the ciruit breakers are closed and the fuses are good. The breakers should be off before you check the capacitor, fan motor, and contactor.
Posted on Jun 04, 2010
Should the heat pump stop when it reaches temp?
Check to see if you have fan on automatic or continuous run ,it should have a setting so you can get air flow at all times or just when unit runs
May 18, 2015 | Mitsubishi Heating & Cooling
Dry pad
Check for plugged holes in the top water distribution tray where the water from the pump exits to wet the pads.
May 04, 2017 | Mastercool 67680 Evaporative Cooler Air...
I have a goodman self contained heat pump that is 3 and 1/2 years old. I wake in the night to hear what sounds like the fan runnning and running and running and air moving thru the vents. Then I will hear...
Heat pumps are a very efficient design when working properly. But lose efficiency the colder it gets outdoors. I usually tell people when it drops below freezing to turn the thermostat to aux or em. heat. A heat pump can remove heat from 20°f air. But not very well. More heat at 30°f air, obviously, and so on. So the colder it is outdoors, the longer it will operate to remove heat from outdoors. And then, if it can't keep up, it brings on the electric heat elements to compensate. Now you are running both outdoor and indoor heat. This is where it's inefficient and costly. Also, the outdoor will start to freeze up. This is normal unless you can see a substantial amount of ice. The heat pump will engage defrost mode, cycling on the electric heat indoors. And defrost mode is actually cooling mode! The reversing valve in the heat pump switches to cooling mode, cycles off the outdoor fan, and defrosts for a set time or temp. So now your electric heat is engaged, and your indoor coil is a COLD coil! Not hot! Very inefficient. These 2 things are why your elec bill is higher in the winter. So it makes sense to me, if the elec heat is going to be on anyway, to move the tstat to aux or em. heat, when it's going to be below freezing outdoors. This will turn off the heat pump and use elected heat only. The only down side to this is, if you don't have enough elec heat to keep you warm, you may need both heat pump and elec heat. So trial end error until you find what works. Also, have a qualified tech check the system for operation and efficiency. Hope this helps!
Apr 08, 2017 | Goodman PHKJ048-1 Air Conditioner
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
2003 vw golf over heating no heat coming from heater fluid is ful
it has 2 get up 2 the themastat temp before fan works,hot air blows threw heater if not a curciut breaker for fan or motor on fan is bad.. system needs 2 be flowing water pump should be, with belt turning
Aug 30, 2009 | 2003 Volkswagen Golf
Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Mar 11, 2009 | Heating & Cooling
Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Feb 19, 2009 | Sharp CV-P09FX Air Conditioner
My Carrier model 38YKC060 heat pump unit fan does not come on and icicles are forming around the bottom. What do I need to do?
You must be having some very cold weather. Heat pumps shut the fan off when the temp. of the coils on the outside hit a certain temperature. That is to increase the pressure inside the unit to get more heat out of it. Your unit also goes into a defrost when ever it gets that cold also. But the compressor turns off also.
Now if your fan never comes on need to check the motor with a ohm meter. And check the capacitor it is a dual one meaning fan and compressor. One side can be out so need to check that also. Turn power off to the outside unit just pull the safety disconnect on the side of the house. Take the capacitor out ohm out the C side and the fan side. You will notice the Herm side meaning compressor. My guess is motor is bad. But I'm not there so concentrate your efforts there. Let me know how it goes okay. Ken
Dec 21, 2008 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
