Question about Motorola Mobility Hint QA30 Cell Phone
How do you fix the loose cable ribbon to the LCD screen? The screen is on and lighted but I cannot see any information. No Caller Id, text messages or contact info.
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on Jun 04, 2010
How to text without your area code coming up
http://smallbusiness.chron.com/iphone-apps-hide-caller-id-text-messages-33649.html
Oct 02, 2014 | Apple iPhone 5
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
My Toshiba A205 started up with a distorted screen. The Toshiba start up screen has yellow letters on a green background. The blue log in screen has swirls of distortion. I can read the text in any program...
Try repositioning the screen in different angles. If it clears up even if only for a minute, the it is most likely the cable or ribbon cable running from the LCD to the motherboard. If not, It may still be a broken wire in the bundle or something more serious like the inverter card or the video chip. The wires on the bundle usually break over time at the point where the bundle runs up by the hinge of the LCD.
Jan 11, 2010 | Toshiba Satellite A205-S5804 PC Notebook
I have no caller id on my text messages or incoming calls
This is normal. T-Mobile does this. Unless the person is in your contact list it only says the number. There is no solution, because that is not a problem. They did this on purpose, I do not know why. But this is how it is.
May 22, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Caller ID on samsung F480 doesn't display
I just called my service provider and they were able to fix it. Just gotta wait 4hrs then turn it off, wait a few seconds then turn it on. heaps quick they knew what i was talking about straight away
May 16, 2009 | Cell Phones
Screen flickers
If light is good and picture flickers, then it is either a bad LCD ribbon cable, or cable not well placed into connector, or a bad LCD display, usually it is the cable.
If picture flickers like light is dimming out and coming back, then it is the LCD lamp, probably in need of replacement.
In some rare case a faulty Video card is causing the problem.
Usually to fix this you need to take apart LCD display and upper laptop plate, to reveal the display cable.
Aug 16, 2008 | HP Pavilion dv1000 Notebook
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Lcd screen
Well, you're not going to fix this without opening up the camera.
The LCD screen should have to wires going to it. One is for the light that illuminates the LCD. That one is obviously working. The other is for the LCD itself - it sounds like that isn't. Either the LCD needs replaced, or that cable is loose or damaged. I'd suggest opening up the camera, finding that cable (it will likely be a thinner cable than the other), and checking for loose connections, or an obvious break or sharp bend in the cable.
Unfortunately, even if you find the cable is damaged, I'm not sure you can get it replaced. If you're not confident you can take this apart and put it back together properly, I'd suggest either taking it to a repair shop, or just using it as is. I'd hate to see you damage it further. If you are confident, however, check that cable. If it's good, contact Samsung about a replacement LCD.
-Dyllan
Dec 20, 2007 | Samsung Digimax i5 Digital Camera
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
LCD LIGHT
LCD screen only displays information when phone is off the hook, goes blank when you hang phone up.
Aug 02, 2007 | Innovage Speaker/Caller ID* LCD Touch...
Motorola Mobility Hint QA30 Cell Phone Logo
665 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
